The popular home theater channel is 5.1 right now. However, I have seen 6.1 and 7.1 channel. Is 7.1 better than 6.1 and 6.1 better than 5.1 and why? Does 7.1 channel mean requiring 7 speakers?
Yes 7 speakers, plus the subwoofer. The 7.1 adds 2 middle speakers with a normal 5.1 set. I have also seen another subwoofer to the rear as well. Not sure which is better...
actually 7.1 adds two REAR surrounds - the side surrounds were supposed to be already there ....
7.1 is no better than 5.1 really unless you have a really large home theater (in which case you can also just add multiple dipole or direct surrounds anyway) .. there are very few films which use 7.1 really (even if they claim so)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
two subwoofers are used in a lot of setups because with two - you can cancel out room nodes (with careful placement) ...
5.1/6 Channels to 2 Channels?
By tmac2085 in forum AudioReplies: 24Last Post: 10th Nov 2011, 20:54 -
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 15:28 -
streaming all tv channels available.
By TinkerThinker in forum Video Streaming DownloadingReplies: 0Last Post: 9th Aug 2009, 15:04 -
MKVs: downmix ac3 6-channels to ac3 2-channels and remux
By kwanbis in forum AudioReplies: 4Last Post: 10th Mar 2009, 16:07 -
Two mono channels
By Digiface in forum AudioReplies: 4Last Post: 13th Jan 2008, 13:14
