Is there a dvd player out there that comes with a default firmware or a upgrade you can get from the company that allows you to change the subtitle color, size, and how long it stays on the screen? Allows you to view videos in a letterbox format where you can set the subtitles to only play on top of the black part at the bottom of the video so they are easy to see no matter what scene is on?
Thinking of bringing my current dvd player back because you can't customize anything.
Subtitle display is controlled via the firmware. There aren't any players that I am aware of that allow you to adjust these settings.
As for displaying on the "black bar", no player supports this option. The subtitles must be displayed on the video output. When WS movies are displayed on your TV with black bars, the bars are not part of the video signal, the TV adds them to properly display the WS video signal.
The few movies that you find that do have subtitles on the black bars, are most likely matted in WS. Meaning the black bars are actually part of the video image.Google is your Friend -
Thanks I don't understand how the Philps DVP 5140/12 and 5960/12 custom firmware can do this then ?Originally Posted by Krispy Kritter
Since subtitles are controlled by the firmware, custom firmware has the subtitle portions altered. It will change the appearance, but it doesn't provide the option for the user to make the adjustments via a menu. There are also custom firmware for the DVP642 that alters the subtitle appearance. All of the changes I have seen affect the font, font color, or background, not the display location.
player with file/custom option and BD-RE/50gbs
By asiafan in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Oct 2011, 17:29 -
Audio options in DVD player, RAW or PCM?
By dzsoul in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Dec 2009, 06:00 -
ATI Catalyst MC - Custom Profile options?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 11th Jul 2009, 12:30 -
Any DVD recorders with custom options?
By pannayar in forum DVD & Blu-ray RecordersReplies: 28Last Post: 22nd Sep 2008, 03:08 -
DVD Player with custom splashscreen
By stavdav in forum DVD & Blu-ray PlayersReplies: 5Last Post: 6th Jun 2008, 05:57
