I have a subtitle. It's timing is constant delay.
Example,
1st line : 00:01:000 -> 00:01:990
2nd line : 00:02:000 -> 00:02:990
3rd line : 00:03:000 -> 00:03:990
I found it's delay about 200 ms.
So I open it in SubResync and retime the 1st line from 00:01:000 to 00:00:800.
So it's change to :
1st line : 00:00:800 -> 00:01:790
2nd line : 00:01:800 -> 00:02:790
3rd line : 00:02:800 -> 00:03:790
If I don't want this, I just want to change the start time only (end time is remain the same)
This is what I want :
1st line : 00:00:800 -> 00:01:990
2nd line : 00:01:800 -> 00:02:990
3rd line : 00:02:800 -> 00:03:990
Are there any solution ?
There're few hundred of line so I can't open it in SubtitleWorkshop and retime it one-by-one.
All suggestion are appreciate.
Best Regards,
First shift all the times up by 200 ms as you did earlier.
In Subtitle Workshop:
Edit/Timings/Time Expander
Expand all durations by 0,200.
Unselect the two "only" conditions, but leave "prevent overlap" just in case.
Subtitle Workshop has a lot of clever functions for adjusting times. Reading the help will be rewarding.
Is there a way to do a timed recording for the hauppage hdpvr 1212?
By yoda313 in forum Capturing and VCRReplies: 4Last Post: 13th Mar 2011, 19:48 -
Any solution to remove hard subtitle from an AVI file?
By dsajkw in forum SubtitleReplies: 9Last Post: 15th Jan 2010, 09:01 -
Current Situation re. +R and -R
By nlec in forum MediaReplies: 1Last Post: 23rd Sep 2008, 16:59 -
It was a stinky situation...
By zzyzzx in forum Off topicReplies: 3Last Post: 18th Jan 2008, 15:27 -
Timed USB Mpeg4 Grabber recording. Is this possible?
By GLOpro in forum Capturing and VCRReplies: 2Last Post: 5th Jul 2007, 19:21
