I am working to build my website, rather going to somewhere else, thus need some info and some help.
what website builder program is best? templets, color, and all necessary requirements.
Is it avaliable to dl from some site?
Extra information could be highly appreciated.
Results 1 to 20 of 20
bobybell
notepad
seriously now (notepad is used a lot though) -- i like CoffeeCup HTML Editor http://www.coffeecup.com/html-editor/
I use Netscape Composer 4.7. I'm sure I am the only person in the world who still has it installed.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
I use coffeecup myself, free version is here: http://www.coffeecup.com/free-editor/
Notepad will work... in fact most text editors are nothing more than glorified version of notepad. Being that they are specifically geared towards making websites they do make things a lot easier, as an example they highlight certain parts of code whereas notepad is going to give you the same font color throughout the document.
Notepad?? do you mean writing text in notepad?
What about graphic, templates, design , models and all other staff than text?
would like to know about it also! as it is most important part in creating website. thanks for your help.bobybell -
Webpages are entirely made up of text either content or HTML markup.
Try this, put "Hello World" in notepad and save it as test.html then open it in your web browser. Congratulations you made your first web page.
A step further:
Code:Hello World I'm Using Bold Text Hello World I'm not using Bold Text
Code:Hello World I'm Using Bold Text Hello World I'm not using Bold Text [img]yourimage.jpg[/img]
http://www.w3schools.com/html/default.asp
The editor mentioned above from coffeecup has a WYSIWG option that allows you to place text and images like you would in MS Word but more importantly it allows you to switch to text mode to see what's going on behind the scenes. -
If you're looking for easy ways to do it you could always try Web Page Maker. It's free to try, but when you publish them you can open them with Notepad and see what it looks like. No actual coding necessary.
SmileSmile
Originally Posted by beavereater
when you get down to it -- even 'ms word' makes a very good single page web editor as it is also WYSIWG and you can save to a web page -- though you have to edit said page and remove all the ms office crap (which is easy to do in notepad) ...
try to stay away from programs like frontpage though IMO"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
That's what I used to get my start but I'd keep away from using that. Frontpage is to be discontinued,
http://office.microsoft.com/en-us/frontpage/FX100743231033.aspx -
Originally Posted by thecoalmanSmile
Smile
Well for starters try and create a fluid layout with a static left nav using only CSS... Try adding a simple piece of javascript code for a mouseover affect, there's plenty of things you can't do.
Also try Notepad++, its a great editor as well. You may want to think about using a content management system to handle your pages, it allows you to create a very complex site and manage it with ease. A couple examples are Joomla (which I use), Mambo, Drupal, and XOOPS
Macromedia Dreamweaver is a good tool but its not free. Though it has lots of features like navigation bar, buttons, frames ... I use to use it once upon a time ! But I think its better than FrontPage.
Check out more details at http://www.adobe.com/products/dreamweaver/When I was born I was so shocked that I could'nt speak for 18 months. -
Although Dreamweaver will do a lot of those things for you, I think it is better to learn the code as well because you will only really be able to integrate cool scripts and debug problems if you can understand the code at some level
Originally Posted by Mylan23
????"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Mylan23, we are talking about website development here and not sendding email
I would suggest learing the basics of HTML, javascripts, vbscripts etc., then create few simple pages and then use a powerful editor like Dreamweaver to create better and feature rich pages. But basics are must to understand What Lies Beneath ...When I was born I was so shocked that I could'nt speak for 18 months.
This website
By Will Hay in forum Off topicReplies: 24Last Post: 17th May 2013, 17:11 -
ISP problem - some website pages load, other website pages don't
By PartingShot in forum ComputerReplies: 15Last Post: 6th Sep 2012, 23:42 -
vod website
By bobmane in forum Video Streaming DownloadingReplies: 1Last Post: 7th Feb 2012, 11:59 -
vod website
By bobmane in forum Video Streaming DownloadingReplies: 0Last Post: 7th Feb 2012, 05:52 -
RipDifferent Website
By Eragon in forum MacReplies: 2Last Post: 10th Jan 2008, 08:29
