I try to compile a dvd with 1 vts, multiple movies all encoded exactly the same in tmpgenc with mpeg2 audio. It gives this error:
" Title - 4
Start building VOB streams - 2210
Muxing elementary streams is in process ... - 2220
Initializing audio packets ... - 3005
Initializing MPEG 1 audio packet ... - 3020
[INFO] - No subtitle stream is provided - 3739
Muxing is in process ... - 2300
Audio packetizing ends - 3025
[ERR] Actual VOBU size mismatches recorded value - 2925
[ERR] Actual VOBU size mismatches recorded value - 2925"
that continues on for several tens of more lines. What does this mean? I check the dvd and i can't find what is / if anything is wrong with it. (but haven't check the whole movie yet). Any help woulld be greatly appreciated.
Also, DLP reads some of my mpeg2 files as having open GOPs even tho i know for a fact that i encoded them in TMPGenc with Closed GOPs.
Thanks for the awesome and quick help I know you guys will give me.
Movie number 4 in your compilation has audio and video length that dont match or are more than 2 seconds in difference. Check the playtime of both the audio file and video file through tmpgenc and make sure the times match.
Looks to me like your video is cut off before the audio finishes. -
here is the screen shot of the gspot program after i opened the file. the length of the audio and video appear to be the same when i play both of the files in Media Player Classic.
I'm not sure of what else to do at this point. Thanks for all the help.
DVD Lab Runtime error c++ compile.aux?
By dcook in forum Authoring (DVD)Replies: 10Last Post: 29th Aug 2010, 22:46 -
Dvd Lab Pro 2.5 Pre Verification fails / Compile.aux error
By Ultron in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2010, 22:45 -
DVD Lab Pro Error
By SirEdward in forum Newbie / General discussionsReplies: 5Last Post: 4th Aug 2008, 17:22 -
dvd lab pro audio error
By tomoftenville in forum Authoring (DVD)Replies: 7Last Post: 6th Dec 2007, 17:05 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
