Ok i have went thru several cd-rs after making a cue and even allowing to overburn and still nothing i tried burning the cue with dvd decrypter...the vcdeasy burner and inside neros burner and after i converted the movie which was 698 MB in avi to mpg it went up to 750 or 850 mb is there a way i can reencode the movie to cut off the credits or is there a way so i can burn it on a cd-r and it fit because i need to no if cutting off credits or making the quality a little less and it will take some of the size away from the 850 mb cause my cd-rs are only 700 MB...im just very curious as i have wrote several questions about all this vcd stuff n bin/cue and all this and i cant seem to find a solution but to come to forums n ask if anyone can help it would be appreciated! Peace
Gods disaster is a brilliant mistake of the things that are one hit wonders!
vcd and svcd are burned to cd in mode 2 format which allows up to about 820,000kb to be burned. import your mpeg into vcdeasy and it will tell you if it's able to fit on 1 cd. if not then you must re-encode to mpeg at a lower bitrate to get a a smaller file size.
What program is there to reencode the mpeg at a lower bitrate? Nero??? I bought my version of VCDEZ but i cant seem to burn it to one cd...aedipuss ty for all the help dude i appreciate it!
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
MPG Files taking a long time to open.
By Ads79 in forum Software PlayingReplies: 8Last Post: 13th Nov 2009, 09:39 -
Cutting a MPG FILE
By peekayem in forum EditingReplies: 3Last Post: 16th Mar 2008, 09:06 -
Cutting File size through muxing HD Audio
By Mastablastacious in forum EditingReplies: 1Last Post: 4th Feb 2008, 02:18 -
cutting out scenes without loss / converting mpg to avi
By denadel in forum EditingReplies: 3Last Post: 19th Jan 2008, 08:18
