Well the old faithful 8X SL Optorite 401 died the other day and I figured I better get a new one. After not having very good luck with my NEC 3520 at work I decided against another NEC. I went to newegg and did some research. Most of the drives were $30-$40 so price really played no part. I read several reviews for Samsung, Lite-On, Plextor, Pioneer, etc and noticed that some of the new drives ar 18X and 20X. I found a Lite-On drive that was 20X and supported both lightscribe and 12x DVD-Ram. It had good reviews so I ordered it. I've never owned a lite-on before and I've heard both good and bad things about them.
I don't expect to find 20x media or even 18x for that matter but I thought it wouldn't hurt to buy the 20x over the 16x since they were basically the same price.
Has anyone used a 20x drive or been able to find media? Also, where can I find an online manual or firmware updates for this drive. Lite-ON's site sucks. DOn't know if I made a mistake yet but we'll see.
There's several threads at CdFreaks.com on your 20x LITEON dvd burner.
http://club.cdfreaks.com/showthread.php?t=197533
http://club.cdfreaks.com/showthread.php?t=191968
There is no firmware upgrade yet for your drive. You'll be able to use SMARTBURN which is a good tool to use. Check out the LITEON FORUM at CdFreaks.com
Sony BDP S-185 Help
By serena91cs in forum DVD & Blu-ray PlayersReplies: 8Last Post: 6th Feb 2012, 13:45 -
Why does my Lite-On DVD burners fail on 8x DL discs?
By Onceler2 in forum MediaReplies: 26Last Post: 5th Jul 2009, 02:11 -
LITE-ON LH-20A1H Problem
By mn072065 in forum DVD & Blu-ray WritersReplies: 11Last Post: 12th Jul 2008, 14:02 -
Tray hard to open on LITE-ON LH-20A1H
By mn072065 in forum DVD & Blu-ray WritersReplies: 3Last Post: 7th Nov 2007, 09:05 -
Opteron 185 or Athlon64 X2
By Heywould3 in forum ComputerReplies: 13Last Post: 24th Jun 2007, 10:48
