Hi I hope someone can help as i think im getting close, i am trying to burn enemy at the gates and i have ripped it using smartripper. i am following the guide on here on how to burn a dvd bigger than 4500mb. im using ReMPEG2 to shrink my movie. the first bit is ok (only takes a couple of minutes)and i create a vinf file as it says in guide, but when i go to encode it i have no idea how to set the bitrate i have tried a few and the est time goes up to about 90 hrs. i have followed the guide how to use it and mad dvd bitrate calc tells me i have vid bitrate of 3888 but when i go to set the bitrate in options on ReMPEG2 its all in 7 figure numbers. pls pls help someone.
many thx also for the last part i need dvdit pe does anyone know where i can download this of the net
<font size=-1>[ This Message was edited by: bigradders on 2002-01-16 16:48:23 ]</font>
Can you be nice to tell me where i can get the program ReMpeg2.
thanks so much
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54
