i have a macbook pro and install finulct pro on it.
but there is big problem for me about capturing.
i connect my sony handycam to computer via firewire.
i start to play movie and click on "capture now" button.
it starts normally and i click excape to stop capturing.
but the program quit unexpectedly...
i remove and install final cut, i log in with an another user but these are not fix the problem.
anyone have an idea???
plzz![]()
guven
first, since you are on aMacbook Pro, this is an intel chip
based macintosh. Are you running Final Cut Pro 5.12 or higher?
Second, this might point to your problem:
Dirty FCP Preferences.
Preference files for FCP are found in User/Library/preferences/final cut pro user data... trash the preference file there, then restart FCP.
Also keep on hand a copy of FCP Rescue for future sakes, to prevent this happening again"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
the version is 5.0
we tried the trash that files i think but it doesnt fix it.
guven -
why roll your eyes....you didn't mention the version before?
and yes there is a 5.12 I mentioned it because it fixes issues
with
WAIT FOR IT
Sony HandyCams
get it here:
FCP Updates for Smart Alecks
not to sound an @$$ and it may be a language barrier issue,
but if you only give half the info in the BEGINNING
don't get testy when someone points out that a version was released
that fixes your issue is handy."Everyone has to learn, so that they can one day teach."
Urban Mac User -
ok i will try it.
i wish it fixes the problem.
but is that why that i cannot capture???
i mean, is it normal to have that kind of problems in 5.0 version?guven -
Sony is Notorious for changing drivers/driver specifications
on their products, all because of a Napolean complex.
JVC, Canon, and Panasonic all seem to comply with Apple
BEFOREHAND, why can't Sony? Email them and ask them.
There is nothing wrong with Apple's FCP, the fault lies
with Sony changing the 1334/1394 driver spec for
their cameras. Apple supplies specs for their default
FW driver, Sony says "uhn-uhn. We want it this Way".
and then Apple has to patch the software to make things
compliant, with Sony. So is it fair? no.
Is it normal? by Sony's standards, yes."Everyone has to learn, so that they can one day teach."
Urban Mac User
FinalCut Pro settings for YouTube work & export?
By MikeBell in forum Video Streaming DownloadingReplies: 1Last Post: 30th Nov 2008, 11:37 -
New TV and a MacBook Pro
By UnPossible in forum Newbie / General discussionsReplies: 0Last Post: 24th Jun 2008, 09:29 -
Turn off bitpacking in FinalCut Pro?
By Routine in forum MacReplies: 2Last Post: 13th Jun 2008, 09:42 -
premiere pro on macbook?
By andrezp in forum EditingReplies: 3Last Post: 20th Aug 2007, 13:30 -
FinalCut Pro 5 Video to DVD
By DigitalGuard in forum MacReplies: 4Last Post: 4th Jul 2007, 13:47
