This site and this forum got to be a real deep mine - plenty of information!
I know this quation might be boring but I dare to ask it.
Can you point me out to the good short clear guide how manualy convert AVI to DVD. There are some good tools that make this task just "by one click" but this is too easy solution if you understand what I mean, this is always interesting to see how it works and to control each step. As far as understand the algorithm shoule be:
FitCD-->CCE-->VirtualDub-->Authoring
Right?
FitCD,
https://forum.videohelp.com/viewtopic.php?p=1487285#1487285
Then open the avisynth script in cce,
https://www.videohelp.com/guides?tools=85&&archive=%25
Convert the audio to ac3 or mpa with ffmpeggui or belight, https://www.videohelp.com/guides.php?guideid=242#242
Author the video and audio with for example Tmpgenc DVD Author, https://www.videohelp.com/guides.php?guideid=740#740 or DVD-lab, https://www.videohelp.com/guides.php?guideid=602#602 -
Thank you, this is exactly what I need - to know opinion of an experienced person what tools to select for optimal work. Thank you again
Problem is, AVI comes in so many "flavors", there's no way to find (or suggest) one method to cater for them all.
Some come with AC3 audio - then you shouldn't reencode the audio at all, but just extract it and reuse it when authoring.
Some may have an odd frame rate that will need frame rate change to fit the DVD std for your TV system - which have an impact on what and how to treat the audio... and on and on and on...
/Mats
An idiot-proof guide to converting DVD's to AVI/MKV/Whatever..
By krishock in forum DVD RippingReplies: 4Last Post: 12th Apr 2009, 13:49 -
Does anyone have an idiots guide to converting telecined dvd's please!
By Emanef in forum DVD RippingReplies: 40Last Post: 18th Jan 2009, 22:04 -
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 01:47 -
I need a guide to convert avi to dvd plz (newbie topic) help
By Death009 in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 07:03 -
several avi files to dvd? where the manual?
By jboyd in forum ffmpegX general discussionReplies: 5Last Post: 1st Sep 2007, 06:10
