I've been doing tons of experimenting trying to create good quality DVDs from MPGs and AVIs I've downloaded. I've been using TMPG to enode the videos in various outputs but when I burn them to DVD, the resultant quality is poor.
Anyone have suggestions for increasing the quality and then burning to DVD?
Thanks!
Hank
The problem isn't that you are losing quality during the conversion. The problem is that you are taking low quality source material (most likely 700-800mb downloads) and expecting to get "dvd quality" files after converting to dvd. This is not possible. You can not get back the quality that was lost to create the low quality downloadable files.
Just get a divx certified dvd player, take the files and burn them to dvd as data (usually about 6 700mb files per disc), and play. No reason to waste time and money doing conversion on low quality material.Google is your Friend
Creating anamorphic DVDs from divx
By Kusie in forum Video ConversionReplies: 5Last Post: 18th Feb 2009, 06:24 -
Automatically creating pngs for DVDAuthor Subtitle MPGs
By tacman1123 in forum Authoring (DVD)Replies: 8Last Post: 5th Jun 2008, 09:15 -
need info on creating new menus on dvds
By TazDevil in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2008, 15:55 -
From 2 DVDs creating one DVD
By asadfx in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2007, 01:56 -
Creating DVDs from h.264 files
By bltkmt in forum Newbie / General discussionsReplies: 18Last Post: 31st May 2007, 18:24
