I have a Panasonic DMES35V DVD VCR combo. I hooked it up over the weekend I recorded on the VHR as well as the DVD with no problems.
I put a pre-recorded VHS tape in and watched with no problem. When I try to eject the tape it will not come out. The door opens then closes and get the message FO6 on the units screen. I can't find anything in tht manual or on Panasonics web site about this.
Any ideas?
TIA
Mark
The "FO6" is the last recorded failure code. In this case, it has detected a failure in the `cassette up` part of tape ejection routine. Some part of the mechanism is likely fouling on something. Can you still operate the tape?
Laserman,
Thanks for the reply, Need to check it out when I get home tonight. What implications are there if the tape plays? What can I do to get the tape out? Any ideas.
Mark -
May be just a `hick-up` in the mechanism, in which case you should be OK. However, if the machine won`t eject the tape, things become complicated. There are essentially 3 methods of tape removal. The first involves nothing more than using the remote in Service Mode, the second, a 9V battery and screwdriver, and lastly, complete removal of the tape mechanism.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error Message
By Perfik in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2007, 12:45 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16 -
Error Message
By Kallid in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Jun 2007, 20:13
