Hopefully someone will be able to assist - just downloaded 'ffmpegx' and went through set up fine
I'm starting a vodcast and trying to convert some files to .flv. Tried a 'dummy-run' on a .mov file I have, ensuring the target format is set right (I think) and clicked encode which brought up another dialogue box titled 'ffmpegX progress' - then it seems to have worked as it creates a .flv file on desktop but the file has no content. Tried it again using other formats (converting to mp4 etc) and the same thing - it creates the file but nothing is in it... help!
Apologies if I haven't explained this right but I'm a totaly newbie to this so please go gentle
Thanks in advance for your time.
DK
try Visual Hub for creating .flv, works pretty cool.
If you want proper help using ffmpegx, post your query
over in the ffmpegx forum, a few clicks down
on the main "forums" page.
However for wider distribution and acceptance by
iTunes for your podcast, use iSquint and create
.mpeg4 files. Your audience will love you for it,
as .flv is unplayable on iPods.
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
ffmpeg doesn't work at all
By Paulo2009 in forum ffmpegX general discussionReplies: 27Last Post: 5th Aug 2009, 00:55 -
Subrip doesn't work
By mtc in forum SubtitleReplies: 7Last Post: 1st Feb 2009, 22:54 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
SUPER doesn't work
By tedgrant in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2007, 15:36
