Hey guys,
Ok, so I've been using tmpgenc for years and years. Love it. But recently with encoding movies from a batch list, its been freezing after the first one or two files are completed. I don't know why. My environmenal settings are set so the DirectShow Multimedia File Reader is at priority 2 with everything else under it. I can't work it out. The files encode fine, but it just won't go past the first few without freezing.
Any suggestions?
I'm thinking maybe its the codecs? If this sounds like its the case, can someone recommend a
safe, newly update codec pack that I should try?
With thanks,
Sgt-Pepper.
You don't want a codec pack. If you think it is codec related, just try reinstalling whatever codecs are needed for the file types you are working with.
Google is your Friend
Freezing Problem!!!!!!!!
By vickynash in forum Newbie / General discussionsReplies: 20Last Post: 26th Jun 2010, 22:37 -
MKVs and subtitles freezing problem
By lylewaggoner in forum SubtitleReplies: 3Last Post: 7th Dec 2008, 20:59 -
strange folder freezing problem with SUPER
By uglijimus in forum Video ConversionReplies: 4Last Post: 12th Aug 2008, 12:02 -
Tmpgenc keeps freezing
By WinSpecToR in forum Video ConversionReplies: 6Last Post: 12th May 2008, 01:08 -
TMPGENC DVDAuthor 3 freezing up during output process
By CodySave in forum Authoring (DVD)Replies: 1Last Post: 21st Jul 2007, 12:57
