Hi All
I am having a go at using AVISynth and the HDR AGC filter to lighten some footage that is too dark. This has been a steep learning curve for me to get this far so I want to double check to make sure I'm on the right track (I was going to ask the filter author over at the doom forums but you have to be registered for 5 days before you can post - WTF??)
Anywhoo
This is the script I used
And this is my resultsCode:AVISource("G:\Video editing\capture\dv-cap.03-12-02_17-50.00.avi") ConvertToYV12(interlaced=true) hdragc(max_gain =3.0, min_gain=1.0, coef_sat=2.5)
Is there anything more I can do to perhaps smooth out the grainy look of the lightened footage?
Results 1 to 12 of 12
This helped clean it up a bit
Code:LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\Convolution3DYV12.dll") AVISource("G:\Video editing\capture\dv-cap.03-12-02_17-50.00.avi") ConvertToYV12(interlaced=true) HDRAGC(coef_sat=2.5,max_gain =3.0,min_gain=1.0,corrector=1.5) SeparateFields() odd=SelectOdd.Convolution3D (0, 32, 128, 16, 64, 10, 0) evn=SelectEven.Convolution3D (0, 32, 128, 16, 64, 10, 0) Interleave(evn,odd) Weave() DoubleWeave.SelectOdd() -
HDRAGC need to be between separate fields/weave when applaying on interlaced material
What, like this?
Code:LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\Convolution3DYV12.dll") AVISource("G:\Video editing\capture\dv-cap.03-12-02_17-50.00.avi") ConvertToYV12(interlaced=true) SeparateFields() odd=SelectOdd.Convolution3D (0, 32, 128, 16, 64, 10, 0) evn=SelectEven.Convolution3D (0, 32, 128, 16, 64, 10, 0) Interleave(evn,odd) HDRAGC(coef_sat=2.5,max_gain =3.0,min_gain=1.0,corrector=1.5) Weave() DoubleWeave.SelectOdd() -
No, not like that.
If you really want to do it right:
LoadPlugin("C:\Path\To\LeakKernelDeint.dll")
LoadPlugin("C:\Path\To\Convolution3D.dll")
MPEG2Source("C\Path\To\Movie.d2v")
LeakKernelBob(Order=1)#if TFF,Order=0 if BFF
SeparateFields()
SelectEvery(4,0,3)#if TFF, SelectEvery(4,1,2) if BFF
Weave()
And encode for TFF. Or, if it matters to you, you can make it for BFF by changing some things. -
ahhhh ok
So, as my video is a DV capture, it should look like this
Code:LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\LeakKernelDeint.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\Convolution3D.dll") AVISource("G:\Video editing\capture\dv-cap.03-12-02_17-50.00.avi") ConvertToYV12(interlaced=true) LeakKernelBob(Order=0)#if TFF,Order=0 if BFF HDRAGC(coef_sat=2.5,max_gain =3.0,min_gain=1.0,corrector=1.5) Convolution3D (0, 32, 128, 16, 64, 10, 0) SeparateFields() SelectEvery(4,1,2)#if TFF, SelectEvery(4,1,2) if BFF Weave() -
That's the way I'd do it. I don't know the output format, so there's a chance you'll have to change the colorspace again. If it's for XviD or HCEnc, you're OK. The Doom9 guys might suggest adding in some AssumeTFFs, as AviSynth has a disconcerting habit of switching back to BFF when you least expect it, but I think you're OK with those filters. If you're not sure, add an Info() to the bottom of the script temporarily to check. Also, before encoding, open the script in VDubMod, find a place with movement , advance a frame at a time, and make sure it plays smoothly.
And if SerbianBoss comes back, he prefers to encode for BFF, and might suggest a slight change.
And I didn't notice that you had DV in the name. I didn't even notice it was an AVI. So my source line was incorrect. But between yourself and guns1inger you got it right. -
I'll be back
Maybe add AssumeBFF() before leakkernelbob and AssumeBFF() after Convolution 3d.
For BFF material i am using SelectEvery(4,0,3)
Fraps footage too dark in AviDemux
By Dr_Asik in forum EditingReplies: 3Last Post: 1st Apr 2011, 05:17 -
Uploading footage from Sony HDR-X105e to a mac?
By toxicquack in forum Capturing and VCRReplies: 1Last Post: 19th Jun 2009, 14:13 -
Dark video, recorded in night club.. Any filter to make brighter?
By nick_gr in forum EditingReplies: 12Last Post: 18th Feb 2009, 06:41 -
hdr sr12(NTSC) or hdr sr12e(PAL) any difference between them?
By deejay.2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Aug 2008, 17:28 -
How to lighten too dark avi files, simply.
By Hal05154 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2008, 18:17
