Apologies, if this issue has already been addressed. I searched but found no answers.
I followed the 'How-to' for making a DVD with subtitles. Though the progress window says the encoding is complete, it 'finishes' way to quickly and I cannot find an output file.
It is not where I saved it and there is no file named movie.DVD.
My understanding of video conversion is extremely rudimentary, so I was hoping someone out there could make some sense of this:
/bin/sh: line 1: /Library/Application Support/ffmpegX/mpeg2enc: cannot execute binary file
Mon Jan 1 21:53:24 CST 2007
INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler
movtoy4m
Copyright 2002-2006 Johan Lindstr??m
All rights reserved..
++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=720x480, frame rate=24000:1001 fps)!!
INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] input: chroma: 4:2:0 JPEG/MPEG-1 (interstitial)
INFO: [yuvscaler] input: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x480, 720x480 being displayed
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] frame rate: 23.976 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
Any thoughts or suggestions would be very much appreciated.
Hmm..
Well, I trashed mpeg2enc and dowloaded and reinstalled it.
When making another attempt at encoding the film, I got this:
/bin/sh: line 1: /Library/Application Support/ffmpegX/mpeg2enc: Malformed Mach-o file
Tue Jan 2 01:12:48 CST 2007
movtoy4m
Still the binary isn't how it's supposed to be: 'malformed'Originally Posted by PoisonGrrrl
Try the download in a .dmg file, provided by tbluewater. That seemed to have solved problems for some people. Then let the ffmpegX components self-installer install the file(s).
The filename doesn't matter; the code in the binary is the wrong version or corrupt. There isn't any other location to clean up.Originally Posted by PoisonGrrrl
(^o^)/
Many thanks, Case.
That did it. (^_^)b
I have had trouble with binary files saved in text format before on this machine, so it is something I will have to look into.
Though I've finally got it to work, I'm still not having successful burns. Playback is completely absent of subtitles on standalone and lacks subs and is jerky on my comp.
Hoping to find some answers to that by sifting through old posts on this forum.
Yeah, I read what you wrote about that elsewhere and have tried encoding with 'set 3:2' selected a couple of times.
That might have been the problem with the subs and especially the jrking, but now both times I've tried encoding, Progress has hung at 100% completion and then "quit unexpectedly"
The How-to's i read for including subs said nothing about the VOBsubs box, but now I am wondering if that needs to be checked...? I am working with an .srt file here, but I see that option on the drop down (though maybe that is just for encoding vob subs to srt - as you can see, i am becoming increasingly confused here).
I am kind of at a loss now.
Following is the crash log, if any of it makes sense to anyone out there,... I'd welcome any insight, ideas, speculation, theory, etc.
Date/Time: 2007-01-03 20:46:48.664 -0600
OS Version: 10.4.8 (Build 8L2127)
Report Version: 4
Command: Progress
Path: /Applications/ffmpegX.app/Contents/Resources/Progress.app/Contents/MacOS/Progress
Parent: WindowServer [61]
Version: ffmpegX Progress version 1.0.2 (1.0.2)
PID: 310
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000008
Thread 0 Crashed:
0 <<00000000>> 0xffff0269 __spin_lock + 9 (cpu_capabilities.h:216)
1 com.apple.HIServices 0x917de038 InitializeDragIPC + 164
2 com.apple.HIServices 0x917ddf8f CoreDragRegisterClientWithOptions + 35
3 com.apple.HIServices 0x917ddf68 CoreDragRegisterClientInModes + 33
4 com.apple.AppKit 0x9333c5c8 coreDragRegisterIfNeeded + 97
5 com.apple.AppKit 0x9333c402 -[NSCoreDragManager registerDragTypes:forWindow:] + 168
6 com.apple.AppKit 0x9333bfdf -[NSWindow(NSDrag) _registerDragTypes:] + 401
7 com.apple.AppKit 0x932c8e6f -[NSWindow(NSDrag) _registerDragTypesIfNeeded] + 66
8 com.apple.AppKit 0x932c79ef -[NSWindow _commonAwake] + 2575
9 com.apple.AppKit 0x932c6f59 -[NSWindow makeKeyAndOrderFront:] + 103
10 com.apple.AppKit 0x9333cd88 -[NSApplication sendAction:to:from:] + 107
11 com.apple.AppKit 0x9333cce1 -[NSControl sendAction:to:] + 101
12 com.apple.AppKit 0x9333ee91 -[NSCell _sendActionFrom:] + 168
13 com.apple.AppKit 0x93351671 -[NSCell trackMouse:inRect
fView:untilMouseUp:] + 1271
14 com.apple.AppKit 0x9336f25d -[NSButtonCell trackMouse:inRect
fView:untilMouseUp:] + 848
15 com.apple.AppKit 0x9336eb0d -[NSControl mouseDown:] + 757
16 com.apple.AppKit 0x9332c3af -[NSWindow sendEvent:] + 5279
17 com.apple.AppKit 0x9331e350 -[NSApplication sendEvent:] + 5023
18 com.apple.AppKit 0x93248dfe -[NSApplication run] + 547
19 com.apple.AppKit 0x9323cd2f NSApplicationMain + 573
20 com.johan@mac.progress 0x00008b56 _start + 228
21 com.johan@mac.progress 0x00008a71 start + 41
Thread 1:
0 libSystem.B.dylib 0x90009857 mach_msg_trap + 7
1 com.unsanity.ape 0xc0001cac __ape_agent + 307
2 libSystem.B.dylib 0x90023d87 _pthread_body + 84
Thread 2:
0 libSystem.B.dylib 0x90048a47 semaphore_timedwait_signal_trap + 7
1 ...ple.CoreServices.CarbonCore 0x90cdd0ab TSWaitOnSemaphoreCommon + 163
2 ...ickTimeComponents.component 0x97da4992 ReadSchedulerThreadEntryPoint + 4895
3 libSystem.B.dylib 0x90023d87 _pthread_body + 84
Thread 3:
0 libSystem.B.dylib 0x90029a6c wait4 + 12
1 libSystem.B.dylib 0x90023d87 _pthread_body + 84
Thread 4:
0 libSystem.B.dylib 0x9000fb5c read + 12
Thread 5:
0 libSystem.B.dylib 0x90024427 semaphore_wait_signal_trap + 7
1 com.apple.Foundation 0x9264b2f8 -[NSConditionLock lockWhenCondition:] + 39
2 com.apple.AppKit 0x93326270 -[NSUIHeartBeat _heartBeatThread:] + 377
3 com.apple.Foundation 0x925f536c forkThreadForFunction + 123
4 libSystem.B.dylib 0x90023d87 _pthread_body + 84
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x90846450 ecx: 0x00000008 edx: 0xffffffff
edi: 0x00000008 esi: 0x00000000 ebp: 0xbffff418 esp: 0xbffff3bc
ss: 0x0000001f efl: 0x00010286 eip: 0xffff0269 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
Binary Images Description:
0x1000 - 0x1cfff com.johan@mac.progress ffmpegX Progress version 1.0.2 (1.0.2) /Applications/ffmpegX.app/Contents/Resources/Progress.app/Contents/MacOS/Progress
0xd9000 - 0xdefff com.unsanity.mightymouse 1.3 (128) /Users/_lethe_/Library/Application Enhancers/Mighty Mouse.ape/Contents/MacOS/Mighty Mouse
0x205000 - 0x244fff com.unsanity.shapeshifter 2.4b5 /Users/_lethe_/Library/Application Enhancers/ShapeShifter.ape/Contents/MacOS/ShapeShifter
0x405000 - 0x424fff com.unsanity.shapeshifter 2.4b5 /Users/_lethe_/Library/Application Enhancers/ShapeShifter.ape/Contents/PlugIns/CocoaStuff.plugIn/Contents/MacOS/CocoaStuff
0x524000 - 0x526fff is.ninjakitten.menufela Menufela version 1.0 (1.0b) /Users/_lethe_/Library/Application Enhancers/menufela.ape/Contents/MacOS/Menufela
0x79f000 - 0x7a6fff com.unsanity.smartcrashreports Smart Crash Reports version 1.2 (1.2) /Users/_lethe_/Library/InputManagers/Smart Crash Reports/Smart Crash Reports.bundle/Contents/MacOS/Smart Crash Reports
0x15b1b000 - 0x15b8cfff com.DivXInc.DivXDecoder 6.2.5 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0x15b9a000 - 0x15beafff com.DivXInc.DivXDecoder 6.0.5 /Library/QuickTime/DivX 6 Decoder.component/Contents/MacOS/DivX 6 Decoder
0x70000000 - 0x7010bfff com.apple.audio.units.Components 1.4.3 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe00000 - 0x8fe49fff dyld 46.9 /usr/lib/dyld
0x90000000 - 0x9016ffff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x901bf000 - 0x901c1fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x901c3000 - 0x901fffff com.apple.CoreText 1.1.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90226000 - 0x902fcfff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9031c000 - 0x90770fff com.apple.CoreGraphics 1.258.38 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90807000 - 0x908cffff com.apple.CoreFoundation 6.4.6 (368.27) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x9090d000 - 0x9090dfff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9090f000 - 0x90a02fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a52000 - 0x90ad1fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90afa000 - 0x90b5efff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x90bcd000 - 0x90bd4fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x90bd9000 - 0x90c4cfff com.apple.framework.IOKit 1.4.6 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90c61000 - 0x90c73fff libauto.dylib /usr/lib/libauto.dylib
0x90c79000 - 0x90f1ffff com.apple.CoreServices.CarbonCore 682.15 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90f62000 - 0x90fcafff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x91002000 - 0x91040fff com.apple.CFNetwork 129.19 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x91053000 - 0x91063fff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x9106e000 - 0x910ecfff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91121000 - 0x9113ffff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9114b000 - 0x91159fff libz.1.dylib /usr/lib/libz.1.dylib
0x9115c000 - 0x912fbfff com.apple.security 4.5.2 (29774) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913f9000 - 0x91401fff com.apple.DiskArbitration 2.1.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91408000 - 0x9142efff com.apple.SystemConfiguration 1.8.6 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91440000 - 0x91447fff libbsm.dylib /usr/lib/libbsm.dylib
0x9144b000 - 0x914c4fff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x91512000 - 0x91512fff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91514000 - 0x9153ffff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91552000 - 0x91626fff com.apple.ColorSync 4.4.8 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91661000 - 0x916defff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9170b000 - 0x917b4fff com.apple.QD 3.10.21 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x917da000 - 0x91825fff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x91844000 - 0x9185afff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91866000 - 0x91880fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9188a000 - 0x918c7fff com.apple.LaunchServices 181 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x918db000 - 0x918e7fff com.apple.speech.synthesis.framework 3.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x918ee000 - 0x91929fff com.apple.ImageIO.framework 1.5.0 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9193b000 - 0x919edfff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91a33000 - 0x91a49fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91a4e000 - 0x91a6cfff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91a71000 - 0x91acffff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91ae1000 - 0x91ae5fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91ae7000 - 0x91b64fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91b68000 - 0x91ba5fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91bab000 - 0x91bc5fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91bca000 - 0x91bccfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91bce000 - 0x91bcefff com.apple.Accelerate 1.3.1 (Accelerate 1.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91bd0000 - 0x91c5efff com.apple.vImage 2.5 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91c65000 - 0x91c65fff com.apple.Accelerate.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91c67000 - 0x91cc0fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91cc9000 - 0x91cedfff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91cf5000 - 0x920fefff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x92138000 - 0x924ecfff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92519000 - 0x92597fff com.apple.DesktopServices 1.3.5 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x925d8000 - 0x92808fff com.apple.Foundation 6.4.7 (567.28) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92914000 - 0x929f2fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x92a0f000 - 0x92afcfff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92b0c000 - 0x92b23fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92b2e000 - 0x92b86fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92b9a000 - 0x92b9afff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92b9c000 - 0x92bacfff com.apple.ImageCapture 3.0.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92bba000 - 0x92bc2fff com.apple.speech.recognition.framework 3.6 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92bc8000 - 0x92bcdfff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92bd3000 - 0x92c64fff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92c78000 - 0x92c7bfff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92c7e000 - 0x92c9bfff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92cab000 - 0x92cb1fff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92cb7000 - 0x92d1afff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92d3e000 - 0x92d7ffff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x92da6000 - 0x92db3fff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92dba000 - 0x92dbffff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92dc4000 - 0x930b6fff com.apple.HIToolbox 1.4.8 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x931bb000 - 0x931c6fff com.apple.opengl 1.4.12 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93236000 - 0x93236fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93238000 - 0x938eefff com.apple.AppKit 6.4.8 (824.42) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x93c6f000 - 0x93ce9fff com.apple.CoreData 90 /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x93d22000 - 0x93de3fff com.apple.audio.toolbox.AudioToolbox 1.4.3 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x93e23000 - 0x93e23fff com.apple.audio.units.AudioUnit 1.4.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x93e25000 - 0x93ff7fff com.apple.QuartzCore 1.4.9 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94048000 - 0x94089fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x94091000 - 0x940cbfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x94251000 - 0x94260fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x94267000 - 0x94272fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x942be000 - 0x942d8fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x942de000 - 0x94597fff com.apple.QuickTime 7.1.3 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x95f0f000 - 0x95f9ffff libcrypto.0.9.dylib /usr/lib/libcrypto.0.9.dylib
0x96443000 - 0x96443fff com.apple.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x96aa5000 - 0x96aaafff com.apple.agl 2.5.9 (AGL-2.5.9) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x97d8d000 - 0x98877fff com.apple.QuickTimeComponents.component 7.1.3 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0xc0000000 - 0xc000efff com.unsanity.ape 2.0.2 /Library/Frameworks/ApplicationEnhancer.framework/Versions/A/ApplicationEnhancer
Model: MacBookPro1,2, BootROM MBP12.0061.B03, 2 processors, Intel Core Duo, 2.16 GHz, 2 GB
Graphics: ATI Radeon X1600, ATY,RadeonX1600, PCIe, 256 MB
Memory Module: BANK 0/DIMM0, 1 GB, DDR2 SDRAM, 667 MHz
Memory Module: BANK 1/DIMM1, 1 GB, DDR2 SDRAM, 667 MHz
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x86), 0.1.27
Bluetooth: Version 1.7.9f12, 2 service, 0 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Network Service: Parallels NAT, Ethernet, en3
Network Service: Parallels Host-Guest, Ethernet, en2
Serial ATA Device: ST9120821AS, 111.79 GB
Parallel ATA Device: MATSHITADVD-R UJ-846, 3.01 GB
USB Device: Built-in iSight, Micron, Up to 480 Mb/sec, 500 mA
USB Device: Apple Internal Keyboard / Trackpad, Apple Computer, Up to 12 Mb/sec, 500 mA
USB Device: IR Receiver, Apple Computer, Inc., Up to 12 Mb/sec, 500 mA
USB Device: Bluetooth HCI, Up to 12 Mb/sec, 500 mA
How to get output file size before converting a file using ffmpeg?
By hayden in forum ProgrammingReplies: 1Last Post: 26th Feb 2012, 08:04 -
Recording 1080i 60 fields/sec vs 1080p 30 frames/sec
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 07:38 -
GOTSent deleting files upon completion
By draco_nite in forum Video ConversionReplies: 1Last Post: 2nd Nov 2010, 11:16 -
CONVERTING MPEG 4 TO MOV FILE, ONLY FIRST 30 SEC OF CLIP WORK,help please !
By Haymaker in forum Video ConversionReplies: 5Last Post: 11th Aug 2010, 18:14 -
Problem encoding to .flv - produces Zero KB file in one sec ?!
By toki4004 in forum ffmpegX general discussionReplies: 11Last Post: 25th Jan 2009, 06:58
