I'm trying to convert an H264 movie to MPEG2 with TMPGEnc using an Avisynth script as the source. The source was a MKV with ASS subtitles which I demuxed and added to the Avisynth script using TextSub. This is my script:
DirectShowSource("my_filename.mkv",audio=false)
TextSub("my_subtitles.ass")
LanczosResize(704,396)
After about 3 minutes of encoding, I noticed the video and subs were out of sync by about 4 seconds! I thought it was TMPGEnc's problem, so I tried to encode to Xvid instead using VirtualDubMod. Again, same problem. Then I used Subtitle Workshop to check the timing of the sub file and compared it with the original MKV, and it was correct. The problem is that the encoded video is running slower than the source video while the hardcoded subs are running at the normal speed.
I then took off the TextSub and LanczosResize because I thought they were causing a slowdown with the encoding process. Using only the DirectShowSource, the video still experienced the same problem on both MPEG2 and Xvid.
What I find most strange is that when I preview in Avisynth, TMPGEnc or VirtualDubMod, the subtitles and video are in sync like they should be. It's during the encoding process where they go out of sync. Input and output files are both 23.976 FPS.
Anyone know what's going on here?
Results 1 to 1 of 1
Video slowdown after converting.
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 11th Apr 2012, 04:07 -
Deinterlace before/after PAL slowdown..?
By Gew in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2010, 17:25 -
Slowdown video other than from Mkv containers
By ranosb in forum Video ConversionReplies: 5Last Post: 3rd Oct 2009, 20:51 -
Video slowdown on DVD-Rs. What's to blame? VCR or DVD Recorder?
By ministry88 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 10th Feb 2009, 19:03 -
Burner Slowdown
By Mitchum22 in forum DVD & Blu-ray WritersReplies: 13Last Post: 28th Jul 2007, 00:01
