Are there any good ones people can recommend?
basically I want a recording of what I'm doing on the screen. I've seen some videos that show the mouse movements along with highlights when the mouse button is pressed. I'd also like to add annotations to the video afterwards using the same program but maybe I can do that with another video editing software afterwards
I've tried CamStudio but it doesn't allow notes or show when the mouse buttons are pressed
any suggestions welcomed 8)
Results 1 to 10 of 10
yeah I've used Wink previously in some old guides 8) but I was hoping there was something else as Wink can be time consuming sometimes
. I'm not sure if Wink shows when a button is clicked either which is what I'm really looking for
I've just noticed Camstudio allows annotations but you can only add them while recording using Pause and not afterwards
. If I'm recording something moving (like a gif) then pause it, add the note and start recording again then it won't look that good
I've also come across DemoStudio which seems to be another version of CamStudio but still doesn't have the mouse click feature I'm looking for
I'm sure there's something out there somewhere
http://www.turbodemo.com/eng/index.htm
Not an endorsement, just a quick search result
Good luck
EDIT and another
http://www.hyperionics.com/IS IT SUPPOSED TO SMOKE LIKE THAT? -
thanks ZAPPER
as you wrote that reply I've just downloaded the demo program of Demo Builder which looks interesting
. At first look this looks the same
I played around with the Adobe Captivate demo last night after downloading it from Adobe but it's $100's for a start! and it still isn't what I'm wanting -
I am gonna try to get a guys phone number to see what program he used to make a cool as hell demo at our office.
He made a demo movie (I don't think it was interactive though, I never used it, only saw parts) for the accounting software that our company uses.
I think that he just started to record the screen movie as he opened the accounting software and he recorded his voice as he worked through the software as the narative (SP) The cool thing that I did like, was that he even made a mistake or two and then showed how to fix them, on purpose or on accident, I think that it helps the end user feel less stressed about using the software.IS IT SUPPOSED TO SMOKE LIKE THAT? -
I did like the way you could create interactive stuff with Adobe Captivate but the price puts me off straight away
. It's like driving a Ferrari to the corner shop in a way as I wouldn't even use it to it's full ability anyway
it also didn't snapshot at the right times when recording so it missed certain parts. I suppose you could add the snapshots manually and then edit afterwards but I want something simple and fast
it simply records the screen (or part of it) and then lets me add notes throughout the video. I'm playing around with Demo Builder at the moment and it's decent enough but only takes snapshot and therefore stuff like animated gifs don't show properly
Demo Builder only outputs to SWF but I suppose I could convert it to a video file. I prefer video files as it allows easier time seeking etc but SWF is OK sometimes
I'll check out the 2 progs you linked to earlier now
Gulp!
I guess I should have looked at the prices first! $100 bucks is about my throw away cash limit and $10 would be better
So.... this takes me to the hillbilly way of doing things.
Output the monitor to the old camcorder while doing the tutorial (ATI AIW (analog)>SonyTRV)
(Actually I haven't tried this yet, but don't see why it wouldn't work)
Send the cam captured vid back to the PC (Sony TRV > DV>WMM)
Edit in your favorite program and add voice over from the sound recorder(WMM or whatever freebie happens to be the one I click on)
Save and distribute in the most appropiate format (CDs there cheap! like me!)
Where there is a will, there is a way!IS IT SUPPOSED TO SMOKE LIKE THAT? -
thanks Coalman
. I've heard of FRAPS from a while back when doing something else but I don't think it will do what I hoping to do
this is an similar video of something I'm wanting to do
example video link (RAR of 13mb extracts to 100mb)
notice how it highlights the mouse clicks, zooms in and out to certain parts and also speeds up in parts when doing many clicks
anyone got any idea of what software is doing this or which software can do it?
Popping, clicks, dropouts when making cuts
By chef2 in forum EditingReplies: 7Last Post: 28th Apr 2012, 20:01 -
how to get the summary of a video file when we point to it by the mouse?
By sumeshkri in forum Newbie / General discussionsReplies: 2Last Post: 3rd Sep 2010, 04:52 -
Standard methods for including video on a website
By innovyse in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2009, 12:36 -
Video Playback is Stuttering/Choppy if the mouse is moved.
By cdubya in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2008, 19:10 -
Making more room via desktop & programs menu
By Marvingj in forum ComputerReplies: 3Last Post: 31st Jul 2007, 13:26
