is there ? or if not, will there be an option for puting audio in the main menu when you make a multi ?
what?
This should answer your question:
As for straightforward, it's your use of the word 'multi' that is confusing. What's a 'multi'?Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
you can use the settings as suggested to add audio to all your menus (if you save as default)... Or you can add audio to menus whilst building the menu by clicking "audio" icon on the left hand side.
Making a multi-track audio CD from a commercial concert DVD ?
By MacPCConsultants in forum AudioReplies: 11Last Post: 2nd Jan 2012, 09:26 -
making teac lcdv2257dvr multi regon
By paul69 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Sep 2010, 04:04 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16 -
have a problem making multi-episode dvds??
By roboroach in forum SubtitleReplies: 0Last Post: 18th Dec 2008, 16:39 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01
