I got a new upconverting Samsung 860hd dvd player which is DivX certified complete with logo on the player to make it official.
However when I download any divx avi file and copy to a CD-r it does play but will stop and pause for roughly +-10sec and resume skipping that amount of time.
Tried various divx files and same thing.
Play it on the computer no problem.
Is there a special way to burn it to play divx? Do you think its the player?
BTW- the picture is outstanding. Dont know if the player is possibly upconverting the divx file to 720p even.
Any help would be appreciated or if it should be posted to another forum.
it is the player IMO (partially) , i tried one of these and it seems that after the great samsung upconverting players of a few years ago -- they have been getting poorer ....
then again -- it could be bad media and/or a bad burn process. try another brand of cd or dvd disk and burn at a lower speed ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
The requirements to be Divx certified are pretty low. There are many Divx settings and features that can cause problems on most players. Also, Divx refers to the video compression -- it's possible that the player is having problems related to the audio.
This web site:
http://www.jarnot.com/twiki/bin/view/Public/DVP642LisaBsAVIGuide
has information about the Philips DVP 642 Divx/DVD player. Much of it is applicable to other players too. That will give you some ideas. -
Thanks for the info.
According to the manual it states about divx:
support divx 3.11 divx 4 with mpeg4 simple profile divx5 mpeg4 simple plus additional features such as bi directional frames. Qpel and GMC also supported.
Xvid mpeg4 compliant
Also just wanted to be sure how it should be burned. I just copied the file to CD. Does it have to be burned a specific way? -
Originally Posted by hightowers
One other thing that isn't discussed much is the way the audio and video are multiplexed together. Typically, you have a frame of video and a "frame" of audio equal in duration to the video frame. Then the next frame of video and audio, etc. But the data can be multiplexed differently. A file might even have all the video first, then all the audio at the end. That doesn't present a problem when playing the file from a hard drive, the drive can seek back and forth very quickly to get the audio and video data. But CDs and DVDs don't seek quickly so this will cause problems.
A simple solution to this is to re-multiplex the audio and video with VirtualDub. Just Open the file, put both audio and video into Direct Stream Copy mode, then Save the file.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
DVD Player capable of playing DivX Plus HD Content
By werty12345 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 11th Nov 2011, 21:11 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Help Playing divx from external HD through dvd player
By Medward in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Sep 2007, 14:14 -
Ripped/burned AVI DivX files not playing in pc or DVD player
By perceptionist in forum DVD RippingReplies: 13Last Post: 4th Jun 2007, 03:55
