    Jan 2007
    I have WinTVR3 and The Screen is Green, I Remove Program And Add it Again Still same
    problem, Also the Color is off in Real Player as well as Windows Media Player. I`ve downloaded
    So many codec(s) To get this feature back, I update all my drivers in my computer and still the same problem, What do i need to get this feature back, I have WinXP, I asked a friend about this He told me go to Restore Point, but I had this problem for a week didn`t realize it
    till I opened my WinTvr3 And played a video on Real Player, If any one can help I really Appreciate it................ Thank You xtimisx
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Have you tried uninstalling and reinstalling WinTVR3? If you play a movie in Real Player WITHOUT opening winTVR3 first, is the video normal?
    Google is your Friend
    USA
    It could be your overlay settings on your video card. Overlay is a mode a lot of players use for video display. If you go to your graphic card settings, you should see overlay adjustments in 'Advanced'.
    You can try VLC Media Player as it will let you turn overlay off or on. (Settings>Preferences>Video>Overlay video output) If the color is correct after changing, then it may be your video card overlay adjustment.
    Jan 2007
    Thank You Krispy Kritter & Redwudz, I found the problem My Video Card needed a Upgrade
    So I did just that And Everything is better now..........Peace xtimisx
