1) Is there any way of convert a swf (flash file) to video or audio file?
2) What is the smallest format of video file?
3) What program do you recommand I use to burn stuff to CD & DVD?
4) I got a xvid file and it plaing 2 sound, how can I make it only play 1? (I not speaking of left, right audio)
Thanks for your help![]()
1) SUPER is one way, Total Video Converter is another
2) As small as you want it to be. Video size is determined by running time x bitrate. Use a small bitrate, get a small file. However you have to balance this against image quality and resolution.
3) Just burning, or encoding ? For just burning, imgburn 2 for DVD video, Prassi ONES for everything else
4) Don't use Windows Media Payer. VLS or Media Player Classic will let you choose which audio you want to have playing. Or you can use virtualdubmod to remove the audio you don't want.Read my blog here.
For 1), it really depends on whether or not the video is an FLV-format Flash video (or even FLV video inside a SWF, if that's possible). If it's a regular SWF, you'll need a different type of converter... or just use a capture program like Camtasia to capture the video as it's playing to an AVI.
If cameras add ten pounds, why would people want to eat them? -
please make your subject title a clearer - thanks
1) If I use a capture program won't the quality be different (sound/picture)?
3) So is Nero 7 any good? I install it and is seem easy to use but there are other stuff install as well, which mess-up my PC. (some picture program)
@BJ_M
Sry, I can't think of what title I should put, I will make it much clear next time. -
Originally Posted by BJ_M
Originally Posted by Fuse
Originally Posted by Fuse) tried to take over the movie filetypes (maybe others like MP3 as well), and I had to reset them back to the other players I was using, but that's about it. Programs stealing file types from other programs is nothing new, unfortunately.
It's been a while...But I think you can use a "Custom" install,
to just install the apps within Nero that you want to use.
Maybe someone can confirm.The Devil`s always.....in the Details!
SOLID ANSWER: .Tivo to .MPG or MOV
By DarkPhoenix77 in forum MacReplies: 24Last Post: 5th Feb 2011, 16:43 -
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 08:38 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 02:54 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 11:34 -
Need someone who has seen Transformers The Movie(animated) to answer Q?
By Denvers Dawgs in forum Off topicReplies: 10Last Post: 27th Jun 2007, 20:42
