  1. Audio gets out of sync with video (very bad),I got Mpeg File for SVCD (20min) authored and burned with Ulead DVD Movie Factory. If I burn the same file with NERO don't have this problem. Does anyone knows anything about it? (Ulead tech support says there's nothing you can do)
    Apr 2001
    ...except maybe don't use Ulead products anymore...
    They are SOOO good at making the programs easy-to-use, and I actually like how you can edit and merge several clips together to edit before you encode (faster and easier than Premiere)... but as you get to encoding, menu creation, and burning, it goes swiftly downhill.
    I'm hearing more and more about the synch problem, or in my case audio clipping done by DVD MovieFactory.
