Hello All
I recorded audio on Sont Sound Forge 8.0 which lasted for 1 hour, however once i saved the file as WMA the audio has gone. The WMA file has saved onto my desktop, however there is no sound when i play the file.....can someone please halp me as it is so fraustating puttin so much effort into creating/recording the audio and then for it to disappearl
I was thinkin maybe is it possible to find the RAW audio on my computer as i have not closed Sound Forge yet???
I would really appreciate some help.
Raw audio should still be there. Did the application crash? SoundForge still keeps tmp files even if there was a crash. Search the drive.
I don't recall exporting to WMA from SoundForge. You could use the Windows Media Encoder instead.
http://www.microsoft.com/windows/windowsmedia/forpros/encoder/default.mspx
I'm away from my SoundForge machine this week.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks to the reply. No the application didnt crash, its weird, i saved the file then all of a sudden there was no audio. The file is still open but there is no peaks and there is no audio playback. when i try to save the file it saves as blank audio......
How can i open the temp files? -
Try searching by date. I forget the file extension used but it opens as if a wav.
If you go into your perferences page, it should list the TEMP directory there. Also, it may have saved the TEMP files in the same directory as where your .WMA files is saved. Check either of those places. Good luck!!
Mako
Using equalizers in Sound Forge 10
By Xdecade in forum AudioReplies: 0Last Post: 6th Jun 2010, 14:12 -
Sony Sound Forge Would you like to launch the associated player for... - No
By c627627 in forum AudioReplies: 0Last Post: 2nd Apr 2010, 20:10 -
Sound Forge Help
By ZOMBE in forum AudioReplies: 2Last Post: 28th Jun 2009, 08:46 -
mp3 only opens by Sony Sound Forge if it's opened / saved in other programs
By c627627 in forum AudioReplies: 7Last Post: 16th Apr 2009, 23:30 -
Goldwave or Sony.Sound.Forge
By lucid_dreams in forum Newbie / General discussionsReplies: 4Last Post: 1st Mar 2008, 01:33
