Hi. The answer to this problem on other threads is to use 'Convert X to DVD' but I am!
I'm burning .avi files, only certain ones have the audio synch issue. Most work fine, I've tried reburning the problem files but the same thing happensOn the computer all the files are fine. Any ideas?
VBR MP3 can cause problems with a lot of software. ConvertXtoDVD usually handles it better than other programs, but even it can get tripped up from time to time.
Try this -> https://forum.videohelp.com/viewtopic.php?t=309224 on the avi first, then convertRead my blog here.
Audio synch problems
By davehaze in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2011, 08:27 -
audio problems when burning a DVD
By cosypete in forum Authoring (DVD)Replies: 3Last Post: 9th May 2010, 19:23 -
PAL/NTSC DVD/VCR combo that will play DVD+R's w/o A/V synch problems?
By wetcamelfood in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Jan 2010, 17:25 -
Audio Synch problem only after burning?
By MCPorche in forum AudioReplies: 1Last Post: 31st Jan 2008, 20:34 -
By zinc in forum AudioReplies: 4Last Post: 6th Jul 2007, 23:22
