Here's some background (others will surely chime in with more info):
Mpeg2enc is slower than ffmpeg, but has different options. For example, if you want to encode kvcds, you must use mpeg2enc; the ffmpeg mpeg engine doesn't support it.
Mplayer must be used when encoding from video_ts folders (ffmpegx automatically chooses it, independently of what you specify). Quicktime reportedly does better, however, at maintaining good audio-video sync under certain conditions.
Command line .. decode w/Quicktime
By kchan in forum ffmpegX general discussionReplies: 2Last Post: 12th Sep 2011, 20:35 -
What is being used to Decode?
By tb582 in forum Video ConversionReplies: 12Last Post: 9th Sep 2008, 16:15 -
ffmpeg faac frame decode failed
By fobster in forum Video ConversionReplies: 2Last Post: 28th Mar 2008, 08:10 -
Decode with quicktime does not work anymore
By macuser1960 in forum ffmpegX general discussionReplies: 8Last Post: 16th Jan 2008, 05:21 -
Decode with Quicktime
By Nekesu04 in forum ffmpegX general discussionReplies: 2Last Post: 13th Jul 2007, 17:25
