    Dec 2006
    Germany
    Hi!
    Does a LG GSA5169D DVD-Writer (with AV Input) support AV-Capturing to Harddisk?
    Which resolutions are supported?
    Thanks in advance
    Opi
    Dec 2005
    According to this site, yes, it supports "AV-Capturing to Harddisk"
    http://www.pcpro.co.uk/shopper/reviews/84054/lg-gsa5169d.html
    Looks like PAL MPEG-2 format.
    First it captures the video to the PC and converts it to MPEG2. Then it burns the converted video to a blank DVD in the drive. You can capture over two hours of video to a single-sided DVD, but you will need space on your hard disk for the video while it's being converted. The minimum specification for all this work is a 1.6GHz processor and 256MB of RAM.
