hello,
I have 4x 800 MB encoded mpg file. I would like to have 9 chapters in this movie which consists of that 4 files.
Should I create one timeline and put all these files on it? I tried to do that with drag&drop but It was impossible. What could I make wrong?
all files are encoded with same profile in MediaConcept MPEG Encoder, (the same res. bitrate, framerate...)
I think you can only create one timeline per file. You would have to pre join all your MPGs sao you have just one video file.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
are you sure?
ISO standard accepts maximum ~1GB files.
At the moment I have Peter Gabriel concert (Growing Up Live) in the DVD-ROM and when i get to /VIDEO_TS folder i see 7x ~1GB files. In fact they are one movie, when I open this movie with PowerDVD there is one long Title which has 18 Chapters. This title consist of that 7 ~1GB VOBs... so It should be possible to create one title from more than one MPG,
but I cant do it with Encore (1,5).
Why? Can you find the reason??
Thanks in advance,
Pawel Nawrocki -
From the Adobe Encore DVD 1.5 user forum, Encore 2.0 can do multiple files on a timeline. Previous versions can't.
http://www.adobeforums.com/cgi-bin/webx/.3bbff663/0 -
thanks creakndale,
I have just checked some of my DVDs and all they have maximum ~1GB VOBs.
ISO 9660 support maxium 2GB files...
It`s time to upgrade to Encore 2.0
thank you all,
Pawel Nawrocki
Encore increasing timeline size
By koberulz in forum Authoring (DVD)Replies: 47Last Post: 9th Nov 2011, 11:19 -
Authoring with Encore CS3, mastering with GPME - when to add ROM?
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 13th Sep 2010, 13:04 -
Encore adds only video to the timeline, not audio.
By Koppel in forum Authoring (DVD)Replies: 2Last Post: 6th Feb 2010, 09:28 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 06:51 -
Encore CS3 - deletes part of video from timeline during build?!?
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 11th Nov 2007, 13:53
