Hey guys;
I just need you to check the compatibility of all these parts and let me know if you think that the case and power supply are good for a BUDGET; and when I say budget; I mean tight a** budget......
CPU - AMD Athlon 64 3500+ Venice 2.2GHz 512KB L2 Cache Socket 939 Processor - Retail $74.00
Motherboard - ASUS A8N-SLI Premium Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard - Retail $132.99
Video Card - PNY VCG7600SXPB GeForce 7600GS 256MB 128-bit GDDR2 PCI Express x16 Video Card - Retail $89.99
Memory - BUFFALO Select 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit Desktop Memory - Retail $93.99
HDD - Western Digital Caviar SE WD1600JSRTL 160GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive - Retail $59.99
DVD Burner - LITE-ON 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 40X CD-ROM IDE DVD Burner included extra White bezel - Retail
Power Supply - ePOWER ZU-550W ATX12V Version 2.0 / EPS12V 550W Power Supply 115/230 V UL, CE, FCC, TUV - Retail $52.99
Case - RAIDMAX Astro ATX-268WB Black 0.7mm Japanese SECC ATX Mid Tower Computer Case - Retail $30
All of these will be purchased from Newegg; and including S&H; the total comes to $597.86.....
And lastly; as for changes made; I've made the tough decision of not going with socket AM2 this time around; because everywhere I look it only leads me to going way out of my budget.......so I don't think I'l l be doing that. However; I did manage to squeeze in the 1 GB of RAM; which is nice;......
...but the main point here is that I'd like you guys to make sure that the power supply I selected has all the necessary connectors I need to plug in all the components to work; because this is my first PC build; and the last thing I want is to have a psu that doesn't have the right connector to power my dvd burner, hdd, cpu, gpu, mobo,,etc.; you get the idea....
P.S. I just want to double check on this; but will the dvd burner I selected be 100% compatible with the mobo??? and also; aside from the psu + case; what do you guys think of the components for this being a n00bs' first build; and it being on an EXTRREEMMELLY tight budget???
All help is greatly appreciated;
Thanx;
Jake
Closed Thread
first of all stop double posting. suggestions were made to you in your other thread.
https://forum.videohelp.com/viewtopic.php?p=1632172#1632172
slayer666metallica, Please continue this in your original thread: https://forum.videohelp.com/viewtopic.php?p=1631559#1631559
Please do not double post.
Moderator redwudz
Panasonic recorder parts compatibility
By rmhartman in forum DVD & Blu-ray RecordersReplies: 4Last Post: 4th Feb 2012, 17:01 -
XviD Settings for PS3 & XBOX360 Compatibility?
By blackflames in forum Video ConversionReplies: 7Last Post: 21st Oct 2009, 06:15 -
AviSynth - JDL_ApplyRange() & FadeIn() Compatibility Issue?
By Typhoon859 in forum Video ConversionReplies: 18Last Post: 4th May 2009, 19:29 -
DVD Media & Player Compatibility
By pbisaillon in forum MediaReplies: 14Last Post: 3rd Nov 2007, 17:07
