After purchasing a LCD HDTV I was thinking of upgrading to a Bell Expressvu HDTV system. My LCD TV only has a YPbPr connection for HD, there is no DVI/HDMI input. I was told by the manufacturer of my LCD TV that the High Definition is on the YPbPr connection of my TV.
I noticed online the Bell ExpressVu HD recevier has both a YPbPr and a DVI Output.
Is there a difference between YPbPr and DVI ?
Will I be actually getting HD if I go from YPbPr on the Satellite to YPbPr on my HD LCD TV?
Can anyone verify this, or anyone using Bell ExpressVu have any thoughts or comments about Bell ExpressVu HD.
Thx
YPbPr will give you HD if you have a bell HD box - you will have almost the same quality as using just the dvi
the bell HD boxes will also upconvert any inputs on the two back panel inputs to 720 or 1080"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Canadian Satellite: Bell or Starchoice - Your experiences
By HillJack in forum DVB / IPTVReplies: 26Last Post: 4th Dec 2011, 10:03 -
Problems with play back packard bell dvd player
By muay in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2010, 12:08 -
Bell 6131 made into hd pvr
By PSS2 in forum Media Center PC / MediaCentersReplies: 0Last Post: 4th Apr 2010, 19:25 -
Help with packard bell ehr2080 dvd hdd recorder and pal60
By rickstain in forum DVD & Blu-ray RecordersReplies: 3Last Post: 31st Jan 2008, 02:59 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 00:32
