I captured a stream from my cablebox using firewire. I was surprised to find that the file, which I expected to be a .ts is an mpeg. As an mpeg, it would not play in WMP or open in HDTVtoMPEG2 so I changed the extension to .ts and I was able to open it in HDTVtoMPEG2. I was then able to convert the clip.
Problem is, the new mpeg plays in WMP with no sound.
1) Any thoughts?
2) Is there a way to play ts files natively?
EDIT - ok, I can play the ts file with videolan. The sound is there. Any thoughts on why the sound is dropping during conversion?
XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card -
Try using projectx for hdtv files. You can use it to strip out the video and audio to do seperate conversions. I use it to demux the video to m2v and then convert with tempgenc plus to dvd compatible format and mux with the original ac3 file.
CableBox DVI
By Splinters in forum Newbie / General discussionsReplies: 10Last Post: 12th Nov 2011, 14:02 -
Comcast HDTV cablebox to DVD recorder. How do I?
By wayshway in forum DVB / IPTVReplies: 12Last Post: 3rd Jan 2011, 15:47 -
Sending a signal from Cablebox
By karl333 in forum DVB / IPTVReplies: 12Last Post: 2nd Nov 2010, 18:03 -
Cablebox Audio to On Board Line In - Is it Safe ?
By somebodeez in forum AudioReplies: 0Last Post: 3rd Sep 2008, 09:24 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 13:56
