Hi,
I have a Panasonic HDD/DVD Recorder (DMR-XW50) which has an SD card slot. The instruction manual says it will recognise MPEG2 video files that are saved in an SD VIDEO folder on the SD Card. Of course, it`s mainly referring to MPEG2 files that have been saved on the card directly from an SD video camera.
However, I have a lot of avi, asf, mp4, 3gp etc, video files on my PC which have been taken with digital cameras and mobile phones, so I want to convert them to a recognisable MPEG2 format for the DVD Recorder`s SD slot.
I know I can convert and burn files to a DVD or SVCD and load them on to the DVD recorder that way, but I want to use the SD Card slot in the future because its much more convenient for loading video files i take with digital still cameras, mobile phones etc.
I have tried converting these files to MPEG2 using Nero7 (SVCD output file) and IMToo MPEG Encoder (MPEG2, SVCD etc), and saving them to an SD Card. But the DVD Recorder wont recognise that there are any video files on the card. (It does recognise the music and picture files, but not the video).
Ive searched the net for appropriate MPEG2 filenames and formats, and read everything on Panasonics website but couldnt find anything to help. Ive also checked the manual for the Panasonic SD Video Camera to see if there are any filenames or extensions it uses to be recognisable on the DVD reorders sd slot. But no luck yet.
My feeling is that I just need to use the right filename structure for the MPEG2 file to be recognised on the SD card for this DVD recorder, but i cant find info on it.
Any help greatly appreciated.
Thanks,
Burton.
Aren't the panasonic mpeg2 cameras using the .mod file extension? Try convert to dvd mpeg2 with for example tmpgenc plus or the imtoo and then rename the files to .mod like video.mod.
yep you`re right, after some more searching ive found they do use *.mod extensions, and i read on another forum that a typical file/folder structure for a Panasonic camera would be SD_VIDEO/PROG1/M0021.MOD. But I tried this, and the dvd recorder still didnt recognise it.
If anyone can confirm the above file/folder structure for a Panasonic SD camcorder is correct, then great. Otherwise, in the meantime i just have to try all different kinds of conversion software. Maybe it needs a particular kind of MPEG2 file.
Thanks for the help anyway. -
I too am having the same problem, I thought putting an mpeg 2 file converted from an avi file on the card, and inserting it into the dvd recorder would be excepted ..but have also found it won`t.
It says SD VIDEO is that different to mpeg 2, I am suprised there is not a simple converter to do the job
Is there not one... -
I have just got a new panasonic recorder and was hoping to do the same thing with the sd card slot. I have got loads of video files that I was hoping to load onto the panasonic. Has anyone found out what how do do this? I have been searching today and found some coversion software called mod converter, but all I think it does is convert from .mod and not to them. Hope someone has found a solution.
erdie :P -
Yes erdie, iI have encountered the same problem, I wanted to convert mpeg 4 and mpeg 2 to .mod file.
But there seems no convertor to do it
Any ideas anyone........?
Watch MPEG2 SD Card Movies on Panasonic TV
By LOWTECH in forum Video ConversionReplies: 2Last Post: 10th Apr 2011, 17:08 -
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 19:23 -
Single Slot Video Card Needed
By ron spencer in forum ComputerReplies: 1Last Post: 1st Jun 2010, 09:56 -
PC Card slot in new PC
By sambat in forum Media Center PC / MediaCentersReplies: 0Last Post: 21st May 2010, 06:24 -
Pci express x1/x16 slot lan card
By SIRCOOKS in forum ComputerReplies: 2Last Post: 3rd Feb 2008, 21:10
