    May 2005
    canada
    im looking for something similar to convertX2Dvd, whereas i can convert avis to dvd quickly.
    i like convertX2Dvd but unfortunately i cant figure out the image/frame-cropping problem it has, and i definately dont want to tweak each and every avi that i convert (as someone suggested in another post by adding a black-surrounding frame into the video - i just simply dont have time to do that for every avi)
    i need something quick that i cant just set and go, and not have to fix/adjust/etc anything.
    and it does not have to be free
    thanx!
  2. Member j4gg3rr's Avatar
    Nov 2005
    Australia
    The FilmMachine is a no fuss 1 clicker that uses CCE, ProCoder or HCenc supplied free.
    It's not as fast as CX but the best quality you'll find in a 1 clicker for sure, especially using Canopus Procoder 2.
    Supports multiple audio tracks and .txt subs(hardcoded/selectable).
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You don't have time to load the avi into FitCD, save an avs file, then load this into ConvertXtoDVD ? Man, you must have a busy life.
    Read my blog here.
    May 2005
    canada
    multiply that by a hundred times.... it adds up, and no i dont have time to do that extra process that many times.
    ultimately id like to find a batch converter that will let me do multiple files at once
