I've had an LG LRH-539 for some time now. I typically burn to DVD+R because I can choose a thumbnail before finalizing -- this does not seem possible when using a DVD-R. Recently, when I insert a blank DVD+R the machine doesn't recognize it or misidentifies it as a DVD+RW. The discs can't be formatted; in the latter case, it asks whether I want to format the DVD+RW...if I say yes, it spits out the discs and tells me to check it. The weird thing is that the DVD+R discs that I finalized just a few days ago are played perfectly by the machine. It does handle DVD-R and DVD-RW discs correctly.
I upgraded my firmware, but that didn't fix the issue.
I'm wondering if anybody has a suggestion.
Is there software that will create an initialized DVD+R disc that the LG can handle? Doesn't it "just" create an open video mode disc? I can't find software that can do this, but it seems likely that if I could format a disc on my PC the machine would recognize it.
Thanks!
I am having the exact Sam issue on the same model; did you get yours fixed? My warranty expires in 15 days, go figure.. I am getting it in but I hope it doesnt blow away the videos on the hard drive...
Regards, John cantermore (at) yahoo dot com ... -
Here is an LG community I go to from time to time for answers:
http://club.cdfreaks.com/forumdisplay.php?f=91 -
That forum is for LG optical drives. Here is the one for DVD+RW Video Recorders:
http://club.cdfreaks.com/forumdisplay.php?f=103
LG BD390 firmware 8.08.539.B - beware!
By andor1999 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 13th Oct 2011, 09:17 -
LG LRH-790 DvD Replacement
By McSatan in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2009, 18:40 -
lg lrh-539 with hard drive
By victoriabears in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Jan 2009, 09:21 -
DVD-ram 2.8GB discs rip trouble
By wodfer in forum DVD RippingReplies: 1Last Post: 27th Jun 2008, 12:49 -
Having trouble with dual layer discs
By red69 in forum Authoring (DVD)Replies: 6Last Post: 8th Sep 2007, 04:16
