I customized Firefox the way I want it (toolbars, buttons, etc), but each time I close it and reopen it it displays a fixed default view, losing my custom settings. I tried browsing thru the preferences but can't find any option to save my custom settings as default. Anyone has a hint? Thanks.
Firefox normally saves your toolbar settings without you having to worry about it. You may have an extension installed that is inadvertently resetting the toolbars to be reset every time you restart... an early version of DownloadHelper used to do that to me (I haven't tried it again since, as I have a number of other extensions and Greasemonkey scripts that can cover that
), and one or two other extensions every once in a while. Or, it could be a theme issue, but that's far less likely.
If cameras add ten pounds, why would people want to eat them? -
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Problems with display of File / Preferences
By Lehmeier in forum Newbie / General discussionsReplies: 7Last Post: 12th Aug 2011, 06:06 -
How do you save the zoom setting in firefox 3.6.15?
By yoda313 in forum ComputerReplies: 11Last Post: 10th Mar 2011, 15:41 -
Take Preferences, Vegas 6.0
By solarblast in forum AudioReplies: 0Last Post: 24th Nov 2008, 11:52 -
Help File for Preferences & Settings
By jhb50 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Jul 2007, 23:53 -
Can't maximize preferences window in 2.5
By maxxjulie in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 28th Jun 2007, 19:48
