im trying to burn a dvd but when i try to burn it says its not a enough free space on the disc it says 4.38 gb r available and 4.43 gb r needed. could it also be that the file is a long file its 2hr 40min. so what i need is a way to burn this file to a dvd as a dvd video.
What application are you using to create the video DVD? If it is Toast 7 just choose Save as Disc Image, then when that is created select it with the Image File setting in the Copy window and Toast will do additional compression when you click the burn button so it will fit a single-layer disc.
Trouble makeing a DVD without Glitches
By mongoo13 in forum Authoring (DVD)Replies: 3Last Post: 27th Apr 2008, 03:51 -
What.When) is DVD video (or mpeg video for DVD) pixel ratio 1:1 or 1:1.09
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 21st Mar 2008, 07:05 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 08:52 -
Makeing NeroDigital Run on a Phillips DVP642
By Trident5 in forum DVD & Blu-ray PlayersReplies: 18Last Post: 1st Mar 2008, 23:13 -
Makeing DVD from avi. with Custom Chapters
By Eternal7331 in forum Authoring (DVD)Replies: 7Last Post: 18th Jan 2008, 20:31
