  1. Like most people I have a couple of films in avi format that i want to encode using TMPGenc.
    I want to encode it in two projects ie: 45 mins each so that when encoded they will fit on two CDs
    I know this is possible using TMPGenc but can someone please give me step by step instructions on how to do it.
    Thx in advance.
  2. I think this will work:
    Open Tmpg
    Load your AVI
    Load your template
    Click Settings
    Set all parameters, IE CBR, Bit rate, ETC
    Go to the Advanced tab
    Select Source Range
    If you move the slider you will see your movie.
    Pick a spot in the middle
    Hit Set End Frame
    Write this number down
    Slide to the start and hit Set Start Frame
    Press Ok then start encoding
    When done:
    Go to Advanced settings
    go to the spot where you ended
    Make that the NEW start Frame
    Go to the end of the movie
    Make that the END of course
    Ensure you save this file as something different, like DISC 2
    Start encoding
    Hope this helps
    Mark
  3. Member tlegion's Avatar
    May 2001
    Sol System
    An easier way would be to set the end point, save the project, go directly back to source range, go to end point, set start point, move to new end point, set end point, save under another name, batch encode.
