  1. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    hello,
    i can create a photo slideshow with various programs but how can i give the user the choice of choosing his own audio
    should i have to create the slideshow in proshow gold and then input that into DVD-lab for the multi audio
    any other ways, any single software solution
    maybe just DVD-Lab
    thankyou
    Dec 2006
    Here,where do you think?
    I've used SSMM for creating a slideshow and you can import any wave sound! Works for me. 8)
    " Who needs Google, my wife knows everything"
  3. Member GeorgeW's Avatar
    Feb 2005
    Do you mean you have a slideshow(s), and you want to give the viewer a choice of the background audio for that slideshow? If so, then you would have to use an authoring package that allows multiple audio tracks (such as DVD LabPro or DVD Architect -- as well as others).
    The DVD Authoring packages sometimes include a slideshow function -- but they are usually not at the same level of slideshow that you can create in a package such as ProShow Gold or MemoriesOnTV, or MuveeAutoproducer, etc... So I always create my slideshows using a separate package, then bring the output video (slideshow) into my authoring package to create the final DVD.
    Regards,
    George
  4. Member Sifaga's Avatar
    Aug 2003
    Thankyou
    now i just have to learn how to use DVD-Lab
  5. Member Sifaga's Avatar
    Aug 2003
    any tips on how to do the multi audio in dvd-lab
    im sought of half way there
    i added 3 audio tracks and was able to swap amongst the audio tracks but creating a audio selection menu seems trickier
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    It is if you want it to be, or it can be very simple. It realy depends on how complex you want the menu to be.
    For a very simple solution, create three buttons on your menu
    Set Language 1
    Set Language 2
    Set Language 3
    Play
    Right-click on Set Language 1 and select Link -> Set Audio -> Audio Stream 1. Make sure Restart Menu is also ticked. repeat for the the next two options, setting the correct audio stream as you go.
    Finally, link the Play button to the main movie title.
    That's the simplest approach. Not fancy, no switched menus and VM commands, but it works.
    Read my blog here.
  7. Member Sifaga's Avatar
    Aug 2003
    worked just like you said, thanks GunSlinger
    now i just need to tweak it
    thanks again
