How can I unlock the settings in the final screen of the Project Wizard (of TMPGEnc) so I can adjust the settings to get a desired file size?
I haven't tried it with the Project Wizard, but with the regular screen, select 'Load', open the 'Extra' folder and select 'unlock.mcf'. But I wouldn't use the Wizard anyway if you are planning to change from the default settings.
And in 'MPEG Setting', you can just right click on the titles for each setting and select 'Unlock'.
You are aware if you change the standard VCD settings, the VCD produced may not be playable on all settop players any more.
At the final screen, click on the Expert button, then right-click on the word "Bitrate" and go to Unlock. Bear in mind that whilst in the Expert section, you should probably go to the system tab, right-click on the word Stream Type and go to unlock, and change this to MPEG-1 Video CD (non standard). Click OK and you should now be able to alter the video bitrate and/or the final filesize.
If in doubt, Google it.
Can I create my own custom Button in TMPGEnc Authoring Workshop 4?
By JackyWang in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2016, 23:14 -
TMPGenc Authoring Works 4: Import custom Buttons
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 31st Aug 2016, 22:14 -
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 15:46 -
Tmpgenc 4.0 Xpress vs FairUse Wizard
By herzeleid in forum Newbie / General discussionsReplies: 0Last Post: 16th Nov 2010, 15:10 -
Tmpgenc DVD Author 3 Custom Background Quality?
By haym in forum Authoring (DVD)Replies: 1Last Post: 29th Jul 2008, 19:49
