I bought a Hauppauge WinTV PVR150 capture card, which has a hardware-based mpeg2 codec. That means it can convert incoming video on the fly.
I assumed I could use this hardware-based mpeg-2 codec to convert, say, avi files to mpeg2 instead of using Tsumani. Is that correct? If so, how do I do this? I can't find the mpeg2 hardware codec name in the list of video codecs in the Compression page of VirtualDub. At least, I don't think I can see the name.
You would need to hook your TV out upto the video input on the card, then play/record. That would mean realtime only encoding, which is perfectly possible with software encoders anyway (and without digital-->analogue-->digital).
Virtualdub codec MPEG-2 / MPEG-1
By Astrogirl in forum Video ConversionReplies: 19Last Post: 10th Dec 2008, 11:38 -
MPEG-2 Codec help
By Nuke Shower in forum Video ConversionReplies: 28Last Post: 23rd Oct 2008, 08:16 -
Which DV codec does capture software select?
By hollowman in forum Capturing and VCRReplies: 21Last Post: 24th Aug 2008, 13:53 -
MPEG-4 v3, which codec to use?
By Zippy1970 in forum Software PlayingReplies: 24Last Post: 7th May 2008, 17:17 -
need mpeg audio codec?
By tomm2000 in forum Video ConversionReplies: 7Last Post: 7th Sep 2007, 20:34
