I'm confused with my new X1300 Pro. There is a 7 pin S-Video connection and the owners guide references and shows a picture of a cable that plugs into the S-Video port and breaks out to the three component RCA plugs. But I can't find a part number anywhere to order it. There is this http://shop.ati.com/product.asp?sku=2550138 but is does not specifically say for the X1300. Then again there's always a DVI-TO-HDTV Adapter http://shop.ati.com/product.asp?sku=2537967 but I am using the DVI port for my LCD ultrasharp monitor. Will I loose quality if I just hook my LCD to the VGA port?
I need to hook up my HDTV as a second monitor for gaming. One other challenge is that its across the room from the PC. I'll need a cable about 30 feet by the time I go under the floor and across the room.
Which port should use for my HDTV and which for the LCD? Should I use a 30 foot s-video cable then convert to component level behind the TV? Or should I convert to component level behind the computer and then run 30 feet of component cable under the floor?
Results 1 to 1 of 1
Cable length component
By Michielvsb in forum ComputerReplies: 4Last Post: 22nd Oct 2011, 08:07 -
Can the mini HDMI or component cable be converted to AV?
By coody in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Aug 2010, 07:14 -
Component cable
By alintatoc in forum Off topicReplies: 3Last Post: 23rd Jan 2010, 09:20 -
Capturing Xbox 360 Video Using Component HD AV Cable
By FrankieB in forum Capturing and VCRReplies: 2Last Post: 18th Feb 2009, 12:21 -
DVI/Component cable
By ajcstr in forum DVB / IPTVReplies: 9Last Post: 16th Oct 2008, 05:25
