Hi all
I'm pretty new to the whole converting to DVd and burning stuff and have zero knowledge on this area so please be very patient with me and give answers/tips in "for dummies" terms.
OK I have started using Avi2DVD which I really like - takes ages but is ideal for newcomers like myself.
I alwyas leave all the settings as the software preselects.
I have approx a 50/50 success rate with the failures resulting in a window on screen which looks a little like a dos window (I will paste below the results from one that has just failed). The result tends to be that it will burn to disc **BUT** only partially.
I can tell , not only from the dos like window but also because the burning process takes much shorter than the successes and you can see only a small part of the disc has a different colour where it has been burned.
Now one of my failures I also tried putting through video DVD maker free.
In one prog it played the full 1st scene (of a three scene movie) and part way into scene 2, whereas with the other software only played for about 2/3 mins before it stopped.
This makes me wonder if it was an issue with the source file ?
Anyway please see below the screen capture from where the dos like window stopped running (when this happens one has to shut it down - whereupon another dos like window does it's bit).
Would be grateful if anyone couls help me out with what's happening here and how to solve.
thanks
INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [???] File D:\My Documents\my pictures\Pics\To Sort\Avi2dvd_temp\Encode
d_Video.m2v looks like an MPEG Video stream.
INFO: [???] File D:\My Documents\my pictures\Pics\To Sort\Avi2dvd_temp\AudioS
tream 1 MP3 2CH.ac3 looks like an AC3 Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard option
s!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (D:\My Documents\my pic
tures\Pics\To Sort\Avi2dvd_temp\Encoded_Video.m2v)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 720
INFO: [???] Frame height : 576
INFO: [???] Aspect ratio : 4:3 display
INFO: [???] Picture rate : 25.000 frames/sec
INFO: [???] Bit rate : 8000000 bits/sec
INFO: [???] Vbv buffer size : 229376 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: AC3 Audio stream 00 (D:\My Documents\my
pictures\Pics\To Sort\Avi2dvd_temp\AudioStream 1 MP3 2CH.ac3)
INFO: [???] AC3 frame size = 1536
INFO: [???] AC3 AUDIO STREAM:
INFO: [???] Bit rate : 49152 bytes/sec (384 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 8520344
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio bd: buf= 16384 frame=000000 sector=00000000
I'm clueless ... about everything
Hi and thanks for the reply.
I have deleted all the ones that wouldn't convert. Next time I get one that doesn't work I'll download that prog and post results here. Is the prog very straight forward to use ?
Thanks again
stefI'm clueless ... about everything -
Well up to now no more problems - typical eh (not that I'm complaining)
If it should happen again I'll revisit this thread and post as you request.
Thanks again for replying.
StefanI'm clueless ... about everything
problems with avi2dvd
By kayla33 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2011, 14:12 -
Avi2dvd menu problems
By bman321 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2009, 20:18 -
avi2dvd sound problems
By justmenow55 in forum Video ConversionReplies: 5Last Post: 13th Aug 2007, 03:58 -
By justmenow55 in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 12:50 -
Creating a Comp DvD problems
By JKG in forum Authoring (DVD)Replies: 1Last Post: 27th May 2007, 05:15
