    Dec 2006
    Hi,
    As of right now I can't play Region 1 DVDs on my PC.
    I have 2 DVD drives, both of which are set to region 1, I've never changed the region.
    All my DVDs are region 1 and none of them will play, I simply get an error saying that the DVD is the wrong region.
    I assume it's not the hardware since it's the same for both players.
    The players are a Liteon LTD163 which came with my dell PC and the other I added long after this problem started, it's a Pacific Digital Mach-12.
    I've also reinstalled windows once since the problem started with no change.
    Oct 2005
    666th portal
    did you actually set them to region 1? i ask because they are delivered with no region set. right click on drive icon properties/hardware/choose drive/properties/dvd region.
    Dec 2006
    I never set them but they are set to region 1.
    It worked just fine for the first year & a half or so that I had it.
