I am capturing analog camcorder tapes with the Hauppauge 250 card to mpeg2. The Hauppauge is working great, no problems (with this forums' help in the past-thanks Jagabo!). Well, I just did a capture that ran up to 6.3 Gigs, one complete cassette of tape. My problem is how to I burn it to a DVD disk for storage? And if I edit it in Pinnacle 10.7 the same problem-it is too big for burning to a DVD.
Just for a laugh, I tried compressing with WinZip; wouldn't touch it, Winzip maxes out at 3Gigs. Tried my favorite, WinRAR, and to its credit it compressed it, but 1 still got 5.5 Gigs.
So-how do I split a tape capture using the Hauppauge 250PVR card and WinTV2000 software?? I am sure I just don't turn off the camcorder half way through the tape. Or do I do it in Pinnacle?
Why not use an authoring program like Ulead DVD MovieFactory? That's the one that came with my Hauppauge PVR USB2, and works ok.
Burn to dual layer dvd.
Okay, for those that are interested, I solved the problem. I used a freeware utility called The File Splitter and it worked great. I chopped the 6.3 Gig mpg into two sections and saved one each to a DVD along with the "re-create" utility provided, and a README notepad instruction on each DVD, so that years from now whoever wants to can rejoin the two files. Then, in Pinnacle, I created two movies, Part 1 and Part 2.
Thanks for all the advice. So far Pinnacle is running fast and perfect; it imported that 6 Gig file and worked with it without a glitch.
Trying to capture a very nifty webpage of just a huge animated gif
By snafubaby in forum Capturing and VCRReplies: 4Last Post: 29th Dec 2010, 06:24 -
HUGE Ripping Problem...HELP
By mgbatman in forum DVD RippingReplies: 9Last Post: 27th Nov 2010, 02:41 -
JVC GY-HM100 has a huge problem !
By Turmap in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 15th Apr 2010, 13:31 -
Single huge lossless AVI file index problem
By Gargalash in forum Newbie / General discussionsReplies: 12Last Post: 20th Nov 2009, 19:37 -
split fields in vdub capture
By greenbag in forum Capturing and VCRReplies: 0Last Post: 18th Jan 2009, 23:50
