    Dec 2006
    I have converted my Video 8 tapes using the Sony Video Recordable DVD Drive (VRD-VC20). The DVD has two directories named VIDEO_RM and VIDEO_TS. I would like to convert these DVD's to format that Pinnacle 9 can edit.
    VIDEO_TS Directory Contents:
    Thanks for your help ...
    JBPhotoBug
    USA
    You could try VOB2MPG and convert the DVD to one large MPEG file. Most any MPEG editor should then work.
    And welcome to our forums.
    Dec 2006
    Thanks redwudz ....
    I scan the forum on a regular basis looking for ideas and problem resolution. In scanning the forum, I noticed the several recommendations to VOB2MPG.
    I attempted to use VOB2MPG. I recieve the attached msg with no converted file.
    Are screen shot attachments OK or should I retype the msg?
    Dec 2006
    OK, I am unable to read the attached screenshot so ...
    VOB2MPG msg:
    Finish processing 1 vobsets Duration: 00:00:00
    Dec 2006
    After hours of research and many trails, I have found a process that solves my issue. I value this forum’s dedication to helping everyone, so I want to let you know the process. I use ShrinkDVD to create a backup of my DVD. I use the output of the backup process on the hard drive for the VOB2MPG input. This generates a MPG file that Pinnacle is able to edit. Case Solved!
