I have the original DVD movie of littleman, i converted the movie and rip the subtitles using subrip 15b4 after a few attempts it worked from my last post. i never realised it had to get it to the HDD before i do it.
I got the subtitles in .srt format but it doesn't show while the movie is playing my player supports .srt format i have half of them in it and they all worked. i have spaces in the filename could that be the problem?
Also i have codes like from another file which my player does not support is there any quick way of getting rip of these? using a spefic program?
Regards
Raiders
Profoundly deaf.
I assume this is in a .srt-file. Open this file in Notepad, goto Edit - Replace and type in the "find what"-field. Leave the "replace with"-field empty and press enter. Repeat, but this time with . All of the codes for italics should now be gone.Originally Posted by Deaf RaidersIn the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
.srt won't work on my Phillips BDP3200/12
By madsboe in forum DVD & Blu-ray PlayersReplies: 7Last Post: 27th Sep 2012, 06:48 -
BD Sup to srt and why they don't work all that weLL.
By cal_tony in forum SubtitleReplies: 2Last Post: 4th May 2011, 10:17 -
Second SRT File Not Recognized on Philips DVD Player
By gonwk in forum SubtitleReplies: 7Last Post: 22nd Dec 2010, 17:13 -
.srt subs will not work
By Easymode in forum SubtitleReplies: 2Last Post: 24th Jan 2010, 00:33 -
.SRT and DVD player question
By EddieDingle in forum SubtitleReplies: 7Last Post: 16th Dec 2009, 17:43
