Hello;
I am ripping DVD to XviD and i created .AVS file but i need a codes for Hue,Saturation,Value for editing my output video(XviD) as like below;
Hue: +5.0
Saturation: +150.0
Value: +0.0
How can i write a code for them to my avisynth (AVS) file?
Thanks for your helps...
I found them below;
I dont know what is my paramater list name?Code:Tweak(parameter_list) hue (-180.0 to +180.0, default 0.0) is used to adjust the color hue of the image. Positive values shift the image towards red. Negative values shift it towards green. sat (0.0 to 10.0, default 1.0) is used to adjust the color saturation of the image. Values above 1.0 increase the saturation. Values below 1.0 reduce the saturation. Use sat=0 to convert to grayscale. bright (-255.0 to 255.0, default 0.0) is used to change the brightness of the image. Positive values increase the brightness. Negative values decrease it. cont (0.0 to 10.0, default 1.0) is used to change the contrast of the image. Values above 1.0 increase the contrast. Values below 1.0 decrease the contrast.
And do i need a drop tweak.dll in Avisynth Plugins folder?
Because i dropped and when i use megui it says tweak.dll is not Avisynth Plugin?
Is there a way to use avisynth plugins/filters within Virtualdub?
By Milardo in forum EditingReplies: 5Last Post: 5th Jan 2011, 03:52 -
Which filters I should use for this anime? (avisynth)
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2010, 12:32 -
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2010, 07:47 -
Avisynth Filters (help pls)
By Enkidu in forum EditingReplies: 14Last Post: 30th Jul 2010, 21:41 -
[Avisynth] What are the filters used in this video?
By Cloudstrifeff7 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2010, 09:40
