Hi All,
I got to convert a video programme to DVD, i used to TMPG to convert my .avi (pal) to .M2v and .mpa, (ntsc) then i used Adobe encore to author the programme. There was no pain in using encore.... but i'm not really happy with the result of TMPG. I used Constant Birate at 8 and Motion Search Precision to Highest. But still there is a Motion blur in the final output. This motion blur looks bad. This is in particular is a dance programme..... and there is lot of movement by the artist and also lot panning in the camera..... how do i make this better????
Regards
Siva
I wouldn't use constant bitrate unless it's 8mbs or higher -- what you want to do is encode at a variable bitrate, 2-pass or greater (can't remember how many passes you can do in TMPGENC, but at least 2 passes), and set your maximum bitrate to 9mbps. I'd set minimum bitrate to 4mpbs, or even higher.
You will lose some playback time this way, so if your program is over an hour, you may have to do two discs or more. This assume quality is your main issue and you don't mind having multiple disc final DVDs.
Good luck! -
What is the source ?
What type of blur ? You can't introduce motion blur when encoding, but you can get other issues if you get, say, field order mixed up.
If you are doing PAL to NTSC conversion you should read this -> https://forum.videohelp.com/viewtopic.php?t=300144Read my blog here.
Hi guns1inger,
Thnx for the link........ i hv already gone thru that...... but this is does'nt helps me as my source is a DVCAM tape..... now after testing various methods...... i think converting the pal video to ntsc video before encoding in Tmpg solve i believe....... but whats the tool do it..... cost is not a problem
Regards
Sivanesan -
Hi All,
Thanks for the replies...... i have solved the problem now. Earlier what i had done is converted the video from PAL to NTSC in TMPG along with encoding to MPG. So i had been getting Motion blur kind of look in the encoded video. Now what i have done is taken the video to Canopus Procoder 2 and converted the video from PAL to NTSC and then encoded as MPG. Now the video is looking as good as the tape.
Regards
Sivanesan
Youtube Video Setting
By harky in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2012, 03:05 -
What digital video format compares to Digital 8?
By jungleexplorer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Dec 2009, 15:00 -
Auto clock setting, another wrinkle in the US analog to digital switchover
By usually_quiet in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2008, 11:04 -
Setting Up Video Camera ? Help!!!
By scustalow in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 23rd Jun 2007, 15:58
