I wanted to tryout DePan-plugin and installed it.
I get an output using AVsP (preview) But I need a review on my script.
1. Where exactly do I place the 'Depan' lines in my script and are they correct?
(position of my Depan-lines are in 'Red'):
2. Because Depanning uses prev+next frames to calculate an average still image and fill inLoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MSharpen.dll")
loadplugin("C:\Program Files\AviSynth 2.5\plugins\depan.dll")
Avisource("C:\DVfootage.avi")
edeintted = last.AssumeBFF().SeparateFields().SelectEven().EED I2(field=-1)
TDeint(order=0,edeint=edeintted)
Lanczos4Resize(480,384)
MSharpen(threshold=20,strength=90,mask=false,highq =true)
ConvertToYV12()
mdata=DePanEstimate
DePanStabilize(data=mdata,cutoff=0.5,dxmax=60,dyma x=30)
#dxmax=left/right default=60
#dymax=top/bottom default=30
missing parts at the sides (am I right?)
Could I loose some of the original video on the sides in the result?
I hope I used the lines correctly.
And I am having trouble understanding the variables.
Thanks.
Haven't used DePan, so I won't comment on the script, but I have used other image stabilizers in the past, and yes, you will lose some image area when stabilizing. How much depends on how much work has to be done to get a smooth image. If your camera was on a tripod and you are smoothing out a little bit of sticking, you won't lose much. If you had a hand-held camera you could lose 5 - 10%.
I haven't been too impressed by the so-called image repair that most of these do, and usually end up having to zoom in slightly to hide the edges that are affected.Read my blog here.
Wich stabelizers do you reccomend?
I think I'm gonna hunt downthat deshake plugin and see if that is a lot more friendlier to use than DePan.
Cuz seriously I'm getting dizzy reading all those nerd-
math-abbreviations I dont understand anyway. -
Hi Wilbert.
It doesnt give en error. But it takes a long time to render just 1 frame though.
And the result frame shows black borders. if they would be filled up automatically (if thats possible) that'll be great. But i'seems it's not the case with my script.
Thanks anyway.
How to get DePan for AviSynth to fix Screen Shake?
By VideoFanatic in forum RestorationReplies: 45Last Post: 30th Nov 2011, 07:49 -
A tool that does it all...correctly!!!
By bdirks in forum Video ConversionReplies: 15Last Post: 5th Jan 2011, 20:27 -
how to join correctly
By heruvim in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 06:55 -
SPDIF not outputting correctly from PC
By bear2616 in forum AudioReplies: 4Last Post: 12th Nov 2008, 16:59 -
Some Videos Do Not Play Correctly
By DJboutit in forum Software PlayingReplies: 5Last Post: 10th Jun 2008, 21:20
