  1. Member rijir2001's Avatar
    Jul 2002
    My PC has a 1Ghz Processor and 512 MB RAM. I have been doing captures using the Pyro AV Link with absolutely no frame loss when captuing from my HI8 camcorder. I just picked up a Sony Mini DV camcorder to transfer some MiniDV tapes to my PC. Watching the tapes on the camcorder screen they appear fine (No glitches). But while doing transfering from the Camcorder to the PC via firewire I am getting regular frame loss. In both cases I have been using WinDV. I capture to a separate hard drive from the OS and it is 7200RPM and defragged regularly. Actually it is virtually clean right now.
    I don't get it. If system resources are a problem why wouldn't I have the same issues with the PryoAV link captures? Why can't I get a good transfer of the DV files from the camcorder?
    Any help appreciated.
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    dunno...try using pyro's dv in from the cam and see what happens...may help to get the answer
    perhaps as something simple as a bad cable
  3. Member rijir2001's Avatar
    Jul 2002
    Could give that a try. As far as the cable goes it is brand new out of the package. So I would assume it should be good. I shouldn't have to go through enother device just to transfer the file. basically.
  4. Member rijir2001's Avatar
    Jul 2002
    Anyone else with any ideas on why this is hapening?
    Dec 2002
    Costa Rica
    I Have a ADSTech PYRO A/V Link connected to my PC thorugh a 6 pin firewire cable.
    When capturing from my D8 cam I have to use a different firewire cable as this CAM has a 4 pin firewire port.
    This is how the Pyro is connected to my PC:
    PC => 6pin - cable - 6pin => Pyro A/V link
    This is how my D8 cam is connected:
    PC => 6pin - cable - 4pin => DV Cam
    Have you tried a new cable?
    Also there are some firewire chipsets (TI, NEC, Via, Agere, etc.) that do not like some brands of devices. The PC I have only worked fine with TI based firewire card (Adaptec). My PC has an Intel CPU but Via chipset.
